Install and maintain
Review the requirements for replacing the boot media in an AFF A150 system
Contributors netapp-jsnyder
Before replacing the boot media in your AFF A150 system, verify that you meet the necessary requirements for a successful replacement. This includes having a USB flash drive formatted to FAT32 with sufficient storage for the ONTAP recovery image and understanding whether you perform a nondisruptive or disruptive replacement.
The boot media stores a primary and secondary set of system (boot image) files that the system uses when it boots. Depending on your network configuration, you can perform either a nondisruptive or disruptive replacement.
Note
NetApp strongly recommends that you enable console logging on the devices you are working with and take the following actions when performing this procedure:
  • Leave AutoSupport enabled during your maintenance. This allows NetApp support to receive diagnostic information if issues occur.
  • Enable session logging for any CLI sessions. This creates a complete record of all commands and system output during the maintenance activity. For guidance on how to enable session logging, see How to configure PuTTY for optimal connectivity to ONTAP systems.
You must have a USB flash drive, formatted to FAT32, with the appropriate amount of storage to hold the image_xxx.tgz file.
You also must copy the image_xxx.tgz file to the USB flash drive for later use in this procedure.
  • The nondisruptive and disruptive methods for replacing a boot media both require you to restore the var file system:
    • For nondisruptive replacement, the HA pair must be connected to a network to restore the var file system.
    • For disruptive replacement, you do not need a network connection to restore the var file system, but the process requires two reboots.
  • You must replace the failed component with a replacement FRU component you received from your provider.
  • It is important that you apply the commands in these steps on the correct node:
    • The impaired node is the node on which you are performing maintenance.
    • The healthy node is the HA partner of the impaired node.
