Install and maintain
Shut down the AFF A150 controllers to replace the chassis
Contributors netapp-jsnyder netapp-martyh
Shut down the controllers in your AFF A150 storage system to prevent data loss and ensure system stability when replacing the chassis.
Option 1: Most configurations
This procedure is for systems with two node configurations. For more information about graceful shutdown when servicing a cluster, see Gracefully shutdown and power up your storage system Resolution Guide - NetApp Knowledge Base.
Before you begin
  • Make sure you have the necessary permissions and credentials:
    • Local administrator credentials for ONTAP.
    • BMC accessibility for each controller.
  • Make sure you have the necessary tools and equipment for the replacement.
Steps
  1. Log into the cluster through SSH or log in from any node in the cluster using a local console cable and a laptop/console.
  2. Stop all clients/host from accessing data on the NetApp system.
  3. Suspend external backup jobs.
  4. If AutoSupport is enabled, suppress case creation and indicate how long you expect the system to be offline:
    system node autosupport invoke -node * -type all -message "MAINT=2h Replace chassis"
  5. Identify the SP/BMC address of all cluster nodes:
    system service-processor show -node * -fields address
  6. Exit the cluster shell:
    exit
  7. Log in to the SP/BMC of each controller using the IP address identified in the previous step:
    • If you log in from the BMC over SSH, connect using the SP/BMC address (for example, ssh admin@<SP/BMC_address>), then enter the command system console and authenticate.
    • If you are using a local console or laptop connected directly to the controller, log in using the same cluster administrator credentials.
  8. Halt the two nodes located in the impaired chassis:
    system node halt -node <node1>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true
    Note For clusters using SnapMirror synchronous operating in StrictSync mode: system node halt -node <node1>,<node2> -skip-lif-migration-before-shutdown true -ignore-quorum-warnings true -inhibit-takeover true -ignore-strict-sync-warnings true
  9. Enter y for each controller in the cluster when you see:
    Warning: Are you sure you want to halt node <node_name>? {y|n}:
  10. Wait for each controller to halt and display the LOADER prompt.
Option 2: Controller is in a MetroCluster configuration
Note Do not use this procedure if your system is in a two-node MetroCluster configuration.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
  • If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (metrocluster node show).
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
    cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
  2. Disable automatic giveback from the console of the healthy controller: storage failover modify –node local -auto-giveback false
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt (enter system password)
    Take over or halt the impaired controller from the healthy controller: storage failover takeover -ofnode impaired_node_name
    When the impaired controller shows Waiting for giveback…​, press Ctrl-C, and then respond y.
