Install and maintain
Install an AFF A150 system using quick graphic instructions
Contributors netapp-jsnyder dougthomp netapp-martyh
Install and cable your AFF A150 storage system using the quick graphic instructions.
Warning: If your system is being installed with ONTAP 9.13.1P8 - 9.13.1P11, ONTAP 9.14.1P1 - 9.14.1P7 or ONTAP 9.15.1 - 9.15.1P2 and your system contains 10 or more internal solid-state drives, you must take additional steps to prepare the system for installation. See issue CONTAP-285173 - ADP does not leave a spare root partition on an AFF A150 with 10 or more internal drives.
The Installation and Setup instructions give graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this guide if you are familiar with installing NetApp systems.
Note The ASA A150 uses the same installation procedure as the AFF A150 system.
