Key specifications for an AFF A50 system
These select specifications describe the AFF A50 storage system configured in a single high availability pair. Visit NetApp Hardware Universe (HWU) for the complete specifications for this system.
AFF A50 specifications at a glance
Platform Configuration: AFF A50 Single Chassis HA Pair
Max Raw Capacity: 4.0392 PB
Memory: 256.0000 GB
Form Factor: 2U chassis with 2 HA controllers and 24 drive slots
PCIe Expansion Slots: 8
Minimum ONTAP Version: ONTAP 9.16.1RC1
Scaleout maximums
Type: NAS; HA Pairs: 12; Raw Capacity: 48.5 PB / 43.0 PiB; Max Memory: 3072 GB
Type: SAN; HA Pairs: 6; Raw Capacity: 24.2 PB / 21.5 PiB; Max Memory: 1536 GB
Type: HA Pair; Raw Capacity: 4.0 PB / 3.6 PiB; Max Memory: 256.0000
I/O
Onboard I/O
No onboard I/O data.
Total I/O
Protocol: Ethernet 100 Gbps; Ports: 16
Protocol: Ethernet 25 Gbps; Ports: 24
Protocol: Ethernet 10 Gbps; Ports: 24
Protocol: FC 64 Gbps; Ports: 24
Protocol: NVMe/FC 64 Gbps; Ports: 24
Ports: 0
Protocol: SAS 12 Gbps; Ports: 16
Management ports
Protocol: Ethernet 1 Gbps; Ports: 2
Protocol: RS-232 115 Kbps; Ports: 4
Protocol: USB 600 Mbps; Ports: 2
Storage networking supported
CIFS
FC
iSCSI
NFS v3
NFS v4.0
NFS v4.1
NFS v4.2
NVMe/FC
NVMe/TCP
S3
S3 with NAS
SMB 2.0
SMB 2.1
SMB 2.x
SMB 3.0
SMB 3.1
SMB 3.1.1
System environment specifications
Typical Power: 3076 BTU/hr
Worst-case Power: 4860 BTU/hr
Weight: 60.7 lb, 27.5 kg
Height: 2U
Width: 19" IEC rack-compliant (17.6" 44.7 cm)
Depth:
Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation; 8% to 80% relative humidity, noncondensing
Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft); 10% to 95% relative humidity, noncondensing, in original container
Acoustic Noise: Declared sound power (LwAd): 8.0; Sound pressure (LpAm) (bystander positions): 70.5 dB
Compliance
Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
Certifications Safety/EMC/EMI: EAC, UKRSEPRO
Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
This product is ENERGY STAR Certified. For more information, visit ENERGY STAR certified data center storage products.
High availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface
Redundant hot-swappable controllers
Redundant hot-swappable power supplies
SAS in-band management over SAS connections for external shelves
