Shut down the controller in an AFF A250 system during the manual boot recovery process
Shut down the controller in your AFF A250 storage system to prevent data loss and maintain system stability during the manual boot media recovery process.
If your storage system is running ONTAP 9.18.1 or later, use the automated boot recovery procedure. If your system is running an earlier version of ONTAP, you must use the manual boot recovery procedure.
Option 1: Most systems
Complete the shutdown of the impaired controller by halting it to the LOADER prompt and capturing the boot environment variables. The LOADER prompt is the safe halted state from which you can replace the boot media.
Take the impaired controller to the LOADER prompt:
If the impaired controller displays… Then… The LOADER prompt
Go to Remove controller module.
Waiting for giveback…Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt (enter system password)
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_nameWhen the impaired controller shows Waiting for giveback…, press Ctrl-C, and then respond
y. -
From the LOADER prompt, enter:
printenvto capture all boot environmental variables. Save the output to your log file.This command may not work if the boot device is corrupted or non-functional.
Option 2: System is in a MetroCluster
Do not use this procedure if your system is in a two-node MetroCluster configuration. |
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (
metrocluster node show).
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Disable automatic giveback from the console of the healthy controller:
storage failover modify –node local -auto-giveback false -
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
y.
After shutting down the controller, you need to replace the boot media.
