Complete the chassis replacement for an AFF A250 system
Reboot the controllers, verify system health, and return the failed part to NetApp to complete the final step in the AFF A250 chassis replacement procedure.
You must verify the HA state of the chassis, and return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
Step 1: Verify and set the HA state of the chassis
You must verify the HA state of the chassis, and, if necessary, update the state to match your system configuration.
In Maintenance mode, from either controller module, display the HA state of the local controller module and chassis:
ha-config showThe HA state should be the same for all components.
If the displayed system state for the chassis does not match your system configuration:
Set the HA state for the chassis:
ha-config modify chassis HA-stateThe value for HA-state can be one of the following:
ha -
mcc -
mccip -
non-ha
Confirm that the setting has changed:
ha-config show
If you have not already done so, recable the rest of your system.
Reinstall the bezel on the front of the system.
Step 2: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
