Review the requirements for replacing a controller in an AFF A250 system
Before replacing the controller in your AFF A250 storage system, ensure you meet the necessary requirements for a successful replacement. This includes verifying all other components in the system are functioning properly, verifying that you have the correct replacement controller, and saving the controller's console output to a text log file.
You must review the prerequisites for the replacement procedure and select the correct one for your version of the ONTAP operating system.
NetApp strongly recommends that you enable console logging on the devices you are working with and take the following actions when performing this procedure:
All drive shelves must be working properly.
If your system is in a MetroCluster configuration, you must review the section Choosing the correct recovery procedure to determine whether you should use this procedure.
You must replace the failed component with a replacement FRU component you received from your provider.
You must be replacing a controller module with a controller module of the same model type. You cannot upgrade your system by just replacing the controller module.
You cannot change any drives or drive shelves as part of this procedure.
In this procedure, the boot device is moved from the impaired controller to the replacement controller so that the replacement controller will boot up in the same version of ONTAP as the old controller module.
It is important that you apply the commands in these steps on the correct systems:
The impaired controller is the controller that is being replaced.
The replacement controller is the new controller that is replacing the impaired controller.
The healthy controller is the surviving controller.
After you've reviewed the requirements to replace the impaired controller, you need to shut down the impaired controller.
