Install and maintain
Install an AFF A250 system using quick graphic instructions
Contributors netapp-martyh thrisun netapp-jsnyder netapp-lisa
Install and cable your AFF A250 storage system using the quick graphic instructions.
The Installation and Setup instructions give graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this guide if you are familiar with installing NetApp systems.
Note The ASA A250 and ASA C250 use the same installation procedure as the AFF A250 system.
