Install and maintain
Switch back aggregates in a two-node MetroCluster configuration for an AFF A300 system
Contributors netapp-jsnyder thrisun netapp-martyh
After completing the boot media replacement, perform the MetroCluster switchback operation. The AFF A300 system supports only manual boot media recovery procedures. Automated boot media recovery is not supported.
This task only applies to two-node MetroCluster configurations.
Steps
  1. Verify that all nodes are in the enabled state: metrocluster node show
    cluster_B::>  metrocluster node show
    DR                           Configuration  DR
    Group Cluster Node           State          Mirroring Mode
    1     cluster_A
                  controller_A_1 configured     enabled   heal roots completed
          cluster_B
                  controller_B_1 configured     enabled   waiting for switchback recovery
    2 entries were displayed.
  2. Verify that resynchronization is complete on all SVMs: metrocluster vserver show
  3. Verify that any automatic LIF migrations being performed by the healing operations were completed successfully: metrocluster check lif show
  4. Perform the switchback by using the metrocluster switchback command from any node in the surviving cluster.
  5. Verify that the switchback operation has completed: metrocluster show
    The switchback operation is still running when a cluster is in the waiting-for-switchback state:
    cluster_B::> metrocluster show
    Cluster              Configuration State    Mode
     Local: cluster_B configured       	switchover
    Remote: cluster_A configured       	waiting-for-switchback
    The switchback operation is complete when the clusters are in the normal state.:
     Local: cluster_B configured      		normal
    Remote: cluster_A configured      		normal
    If a switchback is taking a long time to finish, you can check on the status of in-progress baselines by using the metrocluster config-replication resync-status show command.
  6. Reestablish any SnapMirror or SnapVault configurations.
