Recable the system and reassign disks in an AFF A300 system
Complete the controller replacement for your AFF A300 system by recabling the storage and confirming disk reassignment.
Step 1: Recable the system
Verify the controller module's storage and network connections by using Active IQ Config Advisor.
Download and install Config Advisor.
Enter the information for the target system, and then click Collect Data.
Click the Cabling tab, and then examine the output. Make sure that all disk shelves are displayed and all disks appear in the output, correcting any cabling issues you find.
Check other cabling by clicking the appropriate tab, and then examining the output from Config Advisor.
Step 2: Reassign disks
If the storage system is in an HA pair, the system ID of the new controller module is automatically assigned to the disks when the giveback occurs at the end of the procedure. You must use the correct procedure for your configuration.
Option 1: Verify the system ID change on an HA system
You must confirm the system ID change when you boot the replacement node and then verify that the change was implemented.
This procedure applies only to systems running ONTAP in an HA pair.
If the replacement node is in Maintenance mode (showing the
*>prompt, exit Maintenance mode and go to the LOADER prompt:halt -
From the LOADER prompt on the replacement node, boot the node, entering
yif you are prompted to override the system ID due to a system ID mismatch:boot_ontap -
Wait until the
Waiting for giveback…message is displayed on the replacement node console and then, from the healthy node, verify that the new partner system ID has been automatically assigned:storage failover showIn the command output, you should see a message that the system ID has changed on the impaired node, showing the correct old and new IDs. In the following example, node2 has undergone replacement and has a new system ID of 151759706.
node1> `storage failover show` Takeover Node Partner Possible State Description ------------ ------------ -------- ------------------------------------- node1 node2 false System ID changed on partner (Old: 151759755, New: 151759706), In takeover node2 node1 - Waiting for giveback (HA mailboxes) -
From the healthy node, verify that any coredumps are saved:
Change to the advanced privilege level:
set -privilege advancedYou can respond
Ywhen prompted to continue into advanced mode. The advanced mode prompt appears (*>). -
Save any coredumps:
system node run -node local-node-name partner savecore -
Wait for the `savecore`command to complete before issuing the giveback.
You can enter the following command to monitor the progress of the savecore command:
system node run -node local-node-name partner savecore -s -
Return to the admin privilege level:
set -privilege admin
If your storage system has Storage or Volume Encryption configured, you must restore Storage or Volume Encryption functionality by using one of the following procedures, depending on whether you are using onboard or external key management:
Give back the node:
From the healthy node, give back the replaced node's storage:
storage failover giveback -ofnode replacement_node_nameThe replacement node takes back its storage and completes booting.
If you are prompted to override the system ID due to a system ID mismatch, you should enter
y.If the giveback is vetoed, you can consider overriding the vetoes. -
After the giveback has been completed, confirm that the HA pair is healthy and that takeover is possible:
storage failover showThe output from the
storage failover showcommand should not include the System ID changed on partner message.
Verify that the disks were assigned correctly:
storage disk show -ownershipThe disks belonging to the replacement node should show the new system ID. In the following example, the disks owned by node1 now show the new system ID, 1873775277:
node1> `storage disk show -ownership` Disk Aggregate Home Owner DR Home Home ID Owner ID DR Home ID Reserver Pool ----- ------ ----- ------ -------- ------- ------- ------- --------- --- 1.0.0 aggr0_1 node1 node1 - 1873775277 1873775277 - 1873775277 Pool0 1.0.1 aggr0_1 node1 node1 1873775277 1873775277 - 1873775277 Pool0 . . .
Option 2: Manually reassign the system ID on systems in a two-node MetroCluster configuration
In a two-node MetroCluster configuration running ONTAP, you must manually reassign disks to the new controller's system ID before you return the system to normal operating condition.
This procedure applies only to systems in a two-node MetroCluster configuration running ONTAP.
You must be sure to issue the commands in this procedure on the correct node:
The impaired node is the node on which you are performing maintenance.
The replacement node is the new node that replaced the impaired node as part of this procedure.
The healthy node is the DR partner of the impaired node.
If you have not already done so, reboot the replacement node, interrupt the boot process by entering
Ctrl-C, and then select the option to boot to Maintenance mode from the displayed menu.You must enter
Ywhen prompted to override the system ID due to a system ID mismatch. -
View the old system IDs from the healthy node:
`metrocluster node show -fields node-systemid,dr-partner-systemid`In this example, the Node_B_1 is the old node, with the old system ID of 118073209:
dr-group-id cluster node node-systemid dr-partner-systemid ----------- --------------------- -------------------- ------------- ------------------- 1 Cluster_A Node_A_1 536872914 118073209 1 Cluster_B Node_B_1 118073209 536872914 2 entries were displayed.
View the new system ID at the Maintenance mode prompt on the impaired node:
disk showIn this example, the new system ID is 118065481:
Local System ID: 118065481 ... ... -
Reassign disk ownership (for FAS systems), by using the system ID information obtained from the disk show command:
disk reassign -s old system IDIn the case of the preceding example, the command is:
disk reassign -s 118073209You can respond
Ywhen prompted to continue. -
disk show -aVerify that the disks belonging to the replacement node show the new system ID for the replacement node. In the following example, the disks owned by system-1 now show the new system ID, 118065481:
*> disk show -a Local System ID: 118065481 DISK OWNER POOL SERIAL NUMBER HOME ------- ------------- ----- ------------- ------------- disk_name system-1 (118065481) Pool0 J8Y0TDZC system-1 (118065481) disk_name system-1 (118065481) Pool0 J8Y09DXC system-1 (118065481) . . .
Verify that the coredumps are saved:
system node run -node local-node-name partner savecoreIf the command output indicates that savecore is in progress, wait for savecore to complete before issuing the giveback. You can monitor the progress of the savecore using the
system node run -node local-node-name partner savecore -s command.</info>. -
If the replacement node is in Maintenance mode (showing the *> prompt), exit Maintenance mode and go to the LOADER prompt:
halt -
Boot the replacement node:
boot_ontap -
After the replacement node has fully booted, perform a switchback:
metrocluster switchback -
Verify the MetroCluster configuration:
metrocluster node show - fields configuration-statenode1_siteA::> metrocluster node show -fields configuration-state dr-group-id cluster node configuration-state ----------- ---------------------- -------------- ------------------- 1 node1_siteA node1mcc-001 configured 1 node1_siteA node1mcc-002 configured 1 node1_siteB node1mcc-003 configured 1 node1_siteB node1mcc-004 configured 4 entries were displayed.
Verify the operation of the MetroCluster configuration in Data ONTAP:
Check for any health alerts on both clusters:
system health alert show -
Confirm that the MetroCluster is configured and in normal mode:
metrocluster show -
Perform a MetroCluster check:
metrocluster check run -
Display the results of the MetroCluster check:
metrocluster check show -
Run Config Advisor. Go to the Config Advisor page on the NetApp Support Site at support.netapp.com/NOW/download/tools/config_advisor/.
After running Config Advisor, review the tool's output and follow the recommendations in the output to address any issues discovered.
Simulate a switchover operation:
From any node's prompt, change to the advanced privilege level:
set -privilege advancedYou need to respond with
ywhen prompted to continue into advanced mode and see the advanced mode prompt (*>). -
Perform the switchback operation with the -simulate parameter:
metrocluster switchover -simulate -
