Install and maintain
Hot-swap a fan in an AFF A300 system
Contributors netapp-martyh netapp-jsnyder thrisun dougthomp
Hot-swap a fan module in your AFF A300 system without interrupting service to maintain proper airflow and system cooling.
Note You must replace the fan module within two minutes of removing it from the chassis. System airflow is disrupted and the controller module or modules shut down after two minutes to avoid overheating.
  1. If you are not already grounded, properly ground yourself.
  2. Remove the bezel (if necessary) with two hands, by grasping the openings on each side of the bezel, and then pulling it toward you until the bezel releases from the ball studs on the chassis frame.
  3. Identify the fan module that you must replace by checking the console error messages and looking at the Attention LED on each fan module.
  4. Press down the release latch on the fan module cam handle, and then pull the cam handle downward.
    The fan module moves a little bit away from the chassis.
    Removing the fan
    Callout number 1
    Cam handle
    Callout number 2
    Fan module
    Callout number 2
    Cam handle release latch
    Callout number 4
    Fan module Attention LED
  5. Pull the fan module straight out from the chassis, making sure that you support it with your free hand so that it does not swing out of the chassis.
    Caution The fan modules are short. Always support the bottom of the fan module with your free hand so that it does not suddenly drop free from the chassis and injure you.
  6. Set the fan module aside.
  7. Insert the replacement fan module into the chassis by aligning it with the opening, and then sliding it into the chassis.
  8. Push firmly on the fan module cam handle so that it is seated all the way into the chassis.
    The cam handle raises slightly when the fan module is completely seated.
  9. Swing the cam handle up to its closed position, making sure that the cam handle release latch clicks into the locked position.
    The fan LED should be green after the fan is seated and has spun up to operational speed.
  10. Align the bezel with the ball studs, and then gently push the bezel onto the ball studs.
  11. Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
