Install and maintain
Restore and verify the controller configuration in an AFF A320 system
Contributors netapp-jsnyder
Restore and verify the controller configuration in your AFF A320 system after completing the hardware replacement and booting to Maintenance mode.
Step 1: Set and verify the system time after replacing the controller module
You should check the time and date on the replacement controller module against the healthy controller module in an HA pair, or against a reliable time server in a stand-alone configuration. If the time and date do not match, you must reset them on the replacement controller module to prevent possible outages on clients due to time differences.
About this task
It is important that you apply the commands in the steps on the correct systems:
  • The replacement node is the new node that replaced the impaired node as part of this procedure.
  • The healthy node is the HA partner of the replacement node.
Steps
  1. If the replacement node is not at the LOADER prompt, halt the system to the LOADER prompt.
  2. On the healthy node, check the system time: cluster date show
    The date and time are based on the configured timezone.
  3. At the LOADER prompt, check the date and time on the replacement node: show date
    The date and time are given in GMT.
  4. If necessary, set the date in GMT on the replacement node: set date mm/dd/yyyy
  5. If necessary, set the time in GMT on the replacement node: set time hh:mm:ss
  6. At the LOADER prompt, confirm the date and time on the replacement node: show date
Step 2: Verify and set the HA state of the controller module
You must verify the HA state of the controller module and, if necessary, update the state to match your system configuration.
  1. In Maintenance mode from the new controller module, verify that all components display the same HA state: ha-config show
    The HA state should be the same for all components.
  2. If the displayed system state of the controller module does not match your system configuration, set the HA state for the controller module: ha-config modify controller ha-state
    The value for HA-state can be one of the following:
    • ha
    • mcc
    • mccip
    • non-ha
  3. If the displayed system state of the controller module does not match your system configuration, set the HA state for the controller module: ha-config modify controller ha-state
  4. Confirm that the setting has changed: ha-config show
