Install and maintain
Shut down the controller in an AFF A400 system during the manual boot recovery process
Contributors netapp-jsnyder dougthomp
Shut down the controller in your AFF A400 storage system to prevent data loss and maintain system stability during the manual boot media recovery process.
If your storage system is running ONTAP 9.17.1 or later, use the automated boot recovery procedure. If your system is running an earlier version of ONTAP, you must use the manual boot recovery process.
Option 1: Most configurations
Complete the shutdown of the impaired controller by halting it to the LOADER prompt and capturing the boot environment variables. The LOADER prompt is the safe halted state from which you can replace the boot media.
Steps
  1. Take the impaired controller to the LOADER prompt:
    If the impaired controller displays…​ Then…​
    The LOADER prompt
    Go to Remove controller module.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt (enter system password)
    Take over or halt the impaired controller from the healthy controller: storage failover takeover -ofnode impaired_node_name
    When the impaired controller shows Waiting for giveback…​, press Ctrl-C, and then respond y.
  2. From the LOADER prompt, enter: printenv to capture all boot environmental variables. Save the output to your log file.
    Note This command may not work if the boot device is corrupted or non-functional.
Option 2: Controller is in a MetroCluster configuration
Note Do not use this procedure if your system is in a two-node MetroCluster configuration.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
  • If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (metrocluster node show).
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
    cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h
  2. Disable automatic giveback from the console of the healthy controller: storage failover modify –node local -auto-giveback false
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
Option 3: Controller is in a two-node MetroCluster
To shut down the impaired controller, you must determine the status of the controller and, if necessary, switch over the controller so that the healthy controller continues to serve data from the impaired controller storage.
About this task
  • You must leave the power supplies turned on at the end of this procedure to provide power to the healthy controller.
Steps
  1. Check the MetroCluster status to determine whether the impaired controller has automatically switched over to the healthy controller: metrocluster show
  2. Depending on whether an automatic switchover has occurred, proceed according to the following table:
    If the impaired controller…​ Then…​
    Has automatically switched over
    Proceed to the next step.
    Has not automatically switched over
    Perform a planned switchover operation from the healthy controller: metrocluster switchover
    Has not automatically switched over, you attempted switchover with the metrocluster switchover command, and the switchover was vetoed
    Review the veto messages and, if possible, resolve the issue and try again. If you are unable to resolve the issue, contact technical support.
  3. Resynchronize the data aggregates by running the metrocluster heal -phase aggregates command from the surviving cluster.
    controller_A_1::> metrocluster heal -phase aggregates
    [Job 130] Job succeeded: Heal Aggregates is successful.
    If the healing is vetoed, you have the option of reissuing the metrocluster heal command with the -override-vetoes parameter. If you use this optional parameter, the system overrides any soft vetoes that prevent the healing operation.
  4. Verify that the operation has been completed by using the metrocluster operation show command.
    controller_A_1::> metrocluster operation show
        Operation: heal-aggregates
          State: successful
    Start Time: 7/25/2016 18:45:55
       End Time: 7/25/2016 18:45:56
         Errors: -
  5. Check the state of the aggregates by using the storage aggregate show command.
    controller_A_1::> storage aggregate show
    Aggregate     Size Available Used% State   #Vols  Nodes            RAID Status
    aggr_b2    227.1GB   227.1GB    0% online       0 mcc1-a2          raid_dp, mirrored, normal...
  6. Heal the root aggregates by using the metrocluster heal -phase root-aggregates command.
    mcc1A::> metrocluster heal -phase root-aggregates
    [Job 137] Job succeeded: Heal Root Aggregates is successful
  7. Verify that the heal operation is complete by using the metrocluster operation show command on the destination cluster:
    mcc1A::> metrocluster operation show
      Operation: heal-root-aggregates
          State: successful
     Start Time: 7/29/2016 20:54:41
       End Time: 7/29/2016 20:54:42
         Errors: -
  8. On the impaired controller module, disconnect the power supplies.
