Install and maintain
Install an AFF A400 system using quick graphic instructions
Contributors netapp-jsnyder netapp-martyh netapp-lisa
Install and cable your AFF A400 storage system using the quick graphic instructions.
The Installation and Setup instructions give graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this guide if you are familiar with installing NetApp systems.
Note The ASA A400 uses the same installation procedure as the AFF A400 system.
