Install and maintain
Key specifications for AFF A70
Contributors netapp-martyh Grantglass netapp-jsnyder
Review select specifications for the AFF A70 storage system in a single high availability pair configuration. Visit NetApp Hardware Universe (HWU) for a complete list of AFF A70 specifications.
Platform Configuration: AFF A70 Single Chassis HA Pair
Max Raw Capacity: 6.6096 PB
Memory: 256.0000 GB
Form Factor: 4U chassis with 2 HA controllers and 48 drive slots
PCIe Expansion Slots: 18
Minimum ONTAP Version: ONTAP 9.15.1RC2
Scaleout Maximums
  • NAS: 12 HA Pairs, 79.3 PB / 70.4 PiB Raw Capacity, 3072 GB Max Memory
  • SAN: 6 HA Pairs, 39.7 PB / 35.2 PiB Raw Capacity, 1536 GB Max Memory
  • HA Pair: 6.6 PB / 5.9 PiB Raw Capacity, 256.0000 GB Max Memory
IO
Onboard IO
No onboard IO data.
Total IO
  • Ethernet 200 Gbps: 24 Ports
  • Ethernet 100 Gbps: 36 Ports
  • Ethernet 25 Gbps: 56 Ports
  • Ethernet 10 Gbps: 56 Ports
  • FC 64 Gbps: 56 Ports
  • NVMe/FC 64 Gbps: 56 Ports
  • SAS 12 Gbps: 56 Ports
Management Ports
  • Ethernet 1 Gbps: 2 Ports
  • RS-232 115 Kbps: 4 Ports
  • USB 600 Mbps: 2 Ports
Storage Networking Supported
CIFS; FC; iSCSI; NFS v3; NFS v4.0; NFS v4.1; NFS v4.2; NFSv3/RDMA; NFSv4/RDMA; NVMe/FC ; NVMe/TCP; S3; S3 with NAS; SMB 2.0; SMB 2.1; SMB 2.x; SMB 3.0; SMB 3.1; SMB 3.1.1;
System Environment Specifications
  • Typical Power: 6938 BTU/hr
  • Worst-case Power: 9089 BTU/hr
  • Weight: 118.0 lb, 53.5 kg
  • Height: 4U
  • Width: 19” IEC rack-compliant (17.6” 44.7 cm)
  • Depth: 34.5” (36.6” with cable management bracket)
  • Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation; 8% to 80% relative humidity, noncondensing
  • Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft); 10% to 95% relative humidity, noncondensing, in original container
  • Acoustic Noise: Declared sound power (LwAd): 8.6; Sound pressure (LpAm) (bystander positions): 71.6 dB
Compliance
  • Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
  • Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
  • Certifications Safety/EMC/EMI: EAC, UKRSEPRO
  • Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
  • Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
  • Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High Availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface; Redundant hot-swappable controllers; Redundant hot-swappable power supplies; SAS in-band management over SAS connections for external shelves;
