Install and maintain
Hot-swap a power supply unit in an AFF A70 or AFF A90 system
Contributors netapp-jsnyder dougthomp netapp-martyh netapp-lisa
Replace an AC or DC power supply unit (PSU) in your AFF A70 or AFF A90 system when it fails or becomes faulty, ensuring that your system continues to receive the required power for stable operation. The replacement process involves disconnecting the faulty PSU from the power source, unplugging the power cable, replacing the faulty PSU, and then reconnecting it to the power source.
The power supplies are redundant and hot-swappable. You do not have to shut down the controller to replace a PSU.
About this task
This procedure is written for replacing one PSU at a time. Use the appropriate procedure for your type of PSU: AC or DC.
Important Do not mix PSUs with different efficiency ratings or different input types. Always replace like for like.
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
Option 1: Hot-swap an AC PSU
To replace an AC PSU, complete the following steps.
Steps
  1. Identify the PSU you want to replace, based on console error messages or through the red Fault LED on the PSU.
  2. Disconnect the PSU:
    1. Open the power cable retainer, and then unplug the power cable from the PSU.
  3. Remove the PSU by rotating the handle up, press the locking tab, and then pull PSU out of the controller module.
    Caution The PSU is short. Always use two hands to support it when removing it from the controller module so that it does not suddenly swing free from the controller module and injure you.
    Replace PSU
    Callout number 1
    Terracotta PSU locking tab
  4. Install the replacement PSU in the controller module:
    1. Using both hands, support and align the edges of the replacement PSU with the opening in the controller module.
    2. Gently push the PSU into the controller module until the locking tab clicks into place.
      The power supplies will only properly engage with the internal connector and lock in place one way.
      To avoid damaging the internal connector, do not use excessive force when sliding the PSU into the system.
  5. Reconnect the PSU cabling:
    1. Reconnect the power cable to the PSU.
    2. Secure the power cable to the PSU using the power cable retainer.
    Once power is restored to the PSU, the status LED should be green.
  6. Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
Option 2: Hot-swap a DC PSU
To replace a DC PSU, complete the following steps.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Identify the PSU you want to replace, based on console error messages or through the red Fault LED on the PSU.
  3. Disconnect the PSU:
    1. Unscrew the D-SUB DC cable connector using the thumb screws on the plug.
    2. Unplug the cable from the PSU and set it aside.
  4. Remove the PSU by rotating the handle up, press the locking tab, and then pull the PSU out of the controller module.
    Remove a DC PSU
    Callout number 1
    Thumb screws
    Callout number 2
    D-SUB DC power PSU cable connector
    Callout number 3
    Power supply handle
    Callout number 4
    Blue PSU locking tab
  5. Install the replacement PSU in the controller module:
      Note To avoid damaging the internal connector, do not use excessive force when sliding the PSU into the system.
  6. Reconnect the D-SUB DC power cable:
    1. Plug the power cable connector into the PSU.
    2. Secure the power cable to the PSU with the thumbscrews.
  7. Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
