Install and maintain
Install an AFF A900 system using detailed step-by-step instructions
Contributors dougthomp netapp-jsnyder
Install your AFF A900 storage system using these detailed step-by-step instructions, from preparing the site to bringing up the ONTAP cluster.
Step 1: Prepare for installation
To install your system, you need to create an account on the NetApp Support Site, register your system, and get license keys. You also need to inventory the appropriate number and type of cables for your system and collect specific network information.
You need to have access to the NetApp Hardware Universe for information about site requirements as well as additional information on your configured system.
What you need
You might also want to have access to the ONTAP 9 Release Notes for your version of ONTAP for more information about this system.
You need to provide the following at your site:
  • Rack space for the storage system
  • Phillips #2 screwdriver
  • Additional networking cables to connect your system to your network switch and laptop or console with a Web browser
Steps
  1. Unpack the contents of all boxes.
  2. Record the system serial number from the controllers.
    Example of the system serial number showing location of the number
  3. Inventory and make a note of the number and types of cables you received.
    The following table identifies the types of cables you might receive. If you receive a cable not listed in the table, see the Hardware Universe to locate the cable and identify its use.
    Type of cable…​ Part number and length Connector type For…​
    25 GbE data Cable
    X66240A-05 (112-00639), 0.5m
    X66240A-2 (112-00598), 2m
    X66240A-5 (112-00600), 5m
    Gbe copper SFP
    Network cable
    32 Gb FC (SFP+ Op)
    X66250-2 (112-00342), 2m
    X66250-5 (112-00344), 5m
    X66250-15 (112-00346), 15m
    Gbe copper SFP
    FC optical network cable
    40 GbE network cable
    X66100-1 (112-00542), 1m
    X66100-3 (112-00543), 3m
    X66100-5 (112-00544), 5m
    Gbe copper SFP
    Ethernet data, cluster network
    100 GbE cable
    X66211B-1 (112-00573), 1m
    X66211B-2 (112-00574), 2m
    X66211B-5 (112-00576), 5m
    Gbe copper SFP
    Network,
    NVME storage,
    Ethernet data,
    cluster network
    Optical cables
    X66031A (112-00436), 1m
    X66032A (112-00437), 2m
    X66033A (112-00438), 3m
    LC fiber connector
    FC optical network
    Cat 6, RJ-45 (order dependent)
    Part numbers X6585-R6 (112-00291), 3m
    X6562-R6 (112-00196), 5m
    RJ-45 cable connector
    Management network and Ethernet data
    Micro-USB console cable
    Not applicable
    Micro USB connector
    Console connection during software setup on non-Windows or Mac laptop/console
    Power cables
    Not applicable
    Power cable connector
    Powering up the system
  4. Review the ONTAP Configuration Guide and collect the required information listed in that guide.
Step 2: Install the hardware
You need to install your system in a 4-post rack or NetApp system cabinet, as applicable.
  1. Install the rail kits, as needed.
  2. Install and secure your system using the instructions included with the rail kit.
    Note You need to be aware of the safety concerns associated with the weight of the system.
    Weight lifting caution label
  3. Attach cable management devices (as shown).
    Install cable management arm
  4. Place the bezel on the front of the system.
The following diagram shows a representation of what a typical system looks like and where the major components are located at the rear of the system:
Typical cluster configuration
Step 3: Cable controllers to your network
You can cable the controllers to your network by using the two-node switchless cluster method or by using the cluster interconnect network.
Option 1: Two-node switchless cluster
Management network, data network, and management ports on the controllers are connected to switches. The cluster interconnect ports are cabled on both controllers.
Before you begin
You must have contacted your network administrator for information about connecting the system to the switches.
Be sure to check the direction of the cable pull-tabs when inserting the cables in the ports. Cable pull-tabs are up for all networking module ports.
Cable pull tab direction
Note As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it around and try again.
  1. Use the animation or illustration to complete the cabling between the controllers and to the switches:
    Animation - Cable a two-node switchless cluster
    Two-node switchless network cabling
    Step Perform on each controller
    Callout number 1
    Cable cluster interconnect ports:
    • Slot A4 and B4 (e4a)
    • Slot A8 and B8 (e8a)
    100 Gb connector
    Callout number 2
    Cable controller management (wrench) ports.
    Callout number 3
    Cable 25 GbE network switches:
    Ports in slot A3 and B3 (e3a and e3c) and slot A9 and B9 (e9a and e9c) to the 25 GbE network switches.
    GBe copper SFP
    40GbE host network switches:
    Cable host‐side b ports in slot A4 and B4 (e4b) and slot A8 and B8 (e8b) to the host switch.
    100 GBe cable connector
    Callout number 4
    Cable 32 Gb FC connections:xxx
    Cable ports in slot A5 and B5 (5a, 5b, 5c, and 5d) and slot A7 and B7 (7a, 7b, 7c, and 7d) to the 32 Gb FC network switches.
    Gbe copper SFP
    Callout icon five
    • Strap the cables to the cable management arms (not shown).
    • Connect the power cables to the PSUs and connect them to different power sources (not shown). PSU 1 and 3 provide power to all side A components, while PSU2 and PSU4 provide power to all side B components.
    Power connections
Option 2: Switched cluster
Management network, data network, and management ports on the controllers are connected to switches. The cluster interconnect and HA ports are cabled on to the cluster/HA switch.
Before you begin
Note As you insert the connector, you should feel it click into place; if you do not feel it click, remove it, turn it over and try again.
    Animation - Cable a switched cluster
    Switched network cabling
    Callout number 1
    Cable cluster interconnect a ports:
    • Slot A4 and B4 (e4a) to the cluster network switch.
    • Slot A8 and B8 (e8a) to the cluster network switch.
    100 Gbe cable
    Callout number 2
    RJ45 cables
    Callout number 3
    Gbe copper SFP
    100 Gbe cable
    Callout number 4
    Gbe copper SFP
    Callout icon five
    Power cable
    Power connections
Step 4: Cable controllers to drive shelves
Cable either a single NS224 drive shelf or two NS224 drive shelves to your controllers.
Option 1: Cable the controllers to a single NS224 drive shelf
You must cable each controller to the NSM modules on the NS224 drive shelf on an AFF A900 system.
Before you begin
  • Be sure to check the illustration arrow for the proper cable connector pull-tab orientation. The cable pull-tab for the storage modules are up, while the pull tabs on the shelves are down.
  1. Use the following animation or drawings to cable your controllers to a single NS224 drive shelf.
    Animation - Cable a single NS224 shelf
    Single shelf cabling
    Callout number one
    • Connect controller A port e2a to port e0a on NSM A on the shelf.
    • Connect controller A port e10b to port e0b on NSM B on the shelf.
    100 Gbe QSFP connector
    100 GbE cable
    Callout number two
    • Connect controller B port e2a to port e0a on NSM B on the shelf.
    • Connect controller B port e10b to port e0b on NSM A on the shelf.
    100 GbE cable
Option 2: Cable the controllers to two NS224 drive shelves
You must cable each controller to the NSM modules on the NS224 drive shelves.
Before you begin
  1. Use the following animation or diagram to cable your controllers to two NS224 drive shelves.
    Animation - Cable two NS224 shelves
    Two shelf cabling
    Cabling two NS224 shelves
    Callout number 1
    • Connect controller A port e2a to NSM A e0a on shelf 1.
    • Connect controller A port e10b to NSM B e0b on shelf 1.
    • Connect controller A port e2b to NSM B e0b on shelf 2.
    • Connect controller A port e10a to NSM A e0a on shelf 2.
    Gbe copper SFP
    100 GbE cable
    Callout number 2
    • Connect controller B port e2a to NSM B e0a on shelf 1.
    • Connect controller B port e10b to NSM A e0b on shelf 1.
    • Connect controller B port e2b to NSM A e0b on shelf 2.
    • Connect controller B port e10a to NSM B e0a on shelf 2.
    Gbe copper SFP
    100 GbE cable
Step 5: Complete system setup and configuration
You can complete the system setup and configuration using cluster discovery with only a connection to the switch and laptop, or by connecting directly to a controller in the system and then connecting to the management switch.
Option 1: If network discovery is enabled
If you have network discovery enabled on your laptop, you can complete system setup and configuration using automatic cluster discovery.
  1. Use the following animation or drawing to set one or more drive shelf IDs:
    The NS224 shelves are pre-set to shelf ID 00 and 01. If you want to change the shelf IDs, you must create a tool to insert into the hole where the button is located. See Change a shelf ID - NS224 shelves for detailed instructions.
    Animation - Set NVMe drive shelf IDs
    Changing shelf ID
    Callout number 1
    Shelf end cap
    Callout number 2
    Shelf faceplate
    Callout number 3
    Shelf ID LED
    Callout number 4
    Shelf ID setting button
  2. Turn on the power switches on the power supplies to both nodes.
    Animation - Turn on the power to the controllers
    Power switch
    Note Initial booting might take up to eight minutes.
  3. Make sure that your laptop has network discovery enabled.
    See your laptop's online help for more information.
  4. Use the following animation to connect your laptop to the Management switch.
    Animation - Connect your laptop to the Management switch
    Laptop to switch connection
  5. Select an ONTAP icon listed to discover:
    1. Open File Explorer.
    2. Select Network in the left pane and right-click, then select refresh.
    3. Double-click either ONTAP icon and accept any certificates displayed on your screen.
      Note XXXXX is the system serial number for the target node.
      System Manager opens.
  6. Use System Manager guided setup to configure your system using the data you collected in the ONTAP Configuration Guide.
  7. Set up your account and download Active IQ Config Advisor:
    1. Log in to your existing account or create an account.
    2. Register your system.
    3. Download Active IQ Config Advisor.
  8. Verify the health of your system by running Config Advisor.
  9. After you have completed the initial configuration, go to ONTAP 9 documentation for information about configuring additional features in ONTAP.
Option 2: If network discovery is not enabled
If you are not using a Windows or Mac-based laptop or console or if auto discovery is not enabled, you must complete the configuration and setup using this task.
  1. Cable and configure your laptop or console:
    1. Set the console port on the laptop or console to 115,200 baud with N-8-1.
      Note See your laptop or console's online help for how to configure the console port.
    2. Connect the console cable to the laptop or console using the console cable that came with your system, and then connect the laptop to the management switch on the management subnet.
      Console cable connection
    3. Assign a TCP/IP address to the laptop or console, using one that is on the management subnet.
  2. Use the following animation to set one or more drive shelf IDs:
    Change shelf ID
    Callout number 1
    Shelf end cap
    Callout number 2
    Shelf faceplate
    Callout number 3
    Shelf ID LED
    Callout number 4
  3. Turn on the power switches on the power supplies to both nodes.
    Power switch
  4. Assign an initial node management IP address to one of the nodes.
    If the management network has DHCP…​ Then…​
    Configured
    Record the IP address assigned to the new controllers.
    Not configured
    1. Open a console session using PuTTY, a terminal server, or the equivalent for your environment.
      Note Check your laptop or console's online help if you do not know how to configure PuTTY.
    2. Enter the management IP address when prompted by the script.
  5. Using System Manager on your laptop or console, configure your cluster:
    1. Point your browser to the node management IP address.
      Note The format for the address is https://x.x.x.x.
    2. Configure the system using the data you collected in the ONTAP Configuration Guide
  6. Set up your account and download Active IQ Config Advisor:
  7. Verify the health of your system by running Config Advisor.
  8. After you have completed the initial configuration, go to ONTAP 9 documentation for information about configuring additional features in ONTAP.
