Install an AFF A900 system using quick graphic instructions
Install and cable your AFF A900 storage system using the quick graphic instructions.
The quick guide provides graphic instructions for a typical installation of your system, from racking and cabling, through initial system bring-up. Use this content if you are familiar with installing NetApp systems.
Use the link: AFF A900 Installation and Setup Instructions
The ASA A900 uses the same installation procedure as the AFF A900 system. |
