Install and maintain
Replace the chassis in an AFX 1K system
Contributors netapp-jsnyder netapp-driley
Replace the chassis of your AFX 1K storage system when a hardware failure requires it. The replacement process involves removing the controller, I/O cards, NVRAM12 module, system management module, and power supply units (PSUs), installing the replacement chassis, and reinstalling the chassis components.
Step 1: Remove the PSUs and cables
You need to remove the two power supply units (PSUs) before removing the controller.
Steps
  1. Remove the PSUs:
    1. If you are not already grounded, properly ground yourself.
    2. Unplug power cords from the PSUs.
    3. Remove the two PSUs from the rear of the chassis by rotating the PSU handle up so that you can pull the PSU out, press the PSU locking tab, and then pull PSU out of the chassis.
      Caution The PSU is short. Always use two hands to support it when removing it from the controller module so that it does not suddenly swing free from the controller module and injure you.
      Remove or replace PSU
      Callout number 1
      Terracotta PSU locking tab
    4. Repeat these steps for the second PSU.
  2. Remove the cables:
    1. Unplug the system cables and any SFP and QSFP modules (if needed) from the controller module, but leave them in the cable management device to keep them organized.
      Note Cables should have been labeled at the beginning of this procedure.
    2. Remove the cable management device from the chassis and set it aside.
Step 2: Remove the I/O cards, NVRAM12, and system management module
  1. Check the NVRAM status LED located in slot 4/5 of the system. There is also an NVRAM LED on the front panel of the controller module. Look for the NV icon:
    NVRAM attention and status LED location graphic
    NVRAM
    Callout number 1
    NVRAM status LED
    Callout number 2
    NVRAM attention LED
    • If the NV LED is off, go to the next step.
    • If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
  2. Remove the target I/O module from the chassis:
    Remove I/O module
    Callout number 1
    I/O cam latch
    1. Depress the cam button on the target module.
    2. Rotate the cam latch away from the module as far as it will go.
    3. Remove the module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
      Note Make sure that you keep track of which slot the I/O module was in.
    4. Set the I/O module aside and repeat these steps for any other I/O modules.
  3. Remove the NVRAM12 module:
    1. Depress the locking cam button.
      The cam button moves away from the chassis.
    2. Rotate the cam latch down as far as it will go.
    3. Remove the NVRAM module from the chassis by hooking your finger into the cam lever opening and pulling the module out of the chassis.
      Remove the NVRAM12 module and DIMMs
      Callout number 1
      NVRAM12 cam latch
    4. Set the NVRAM module on a stable surface.
  4. Remove the system management module:
    1. Depress the cam button on the System Management module.
    2. Rotate the cam lever down as far as it will go.
    3. Loop your finger into the hole on the cam lever and pull the module straight out of the system.
      System Management remove
      Callout number 1
      System Management module cam latch
Step 3: Remove the controller module
  1. On the front of the unit, hook your fingers into the holes in the locking cams, squeeze the tabs on the cam levers, and gently, but firmly rotate both latches toward you at the same time.
    The controller module moves slightly out of the chassis.
    Controller remove graphic
    Callout number 1
    Locking cam latches
  2. Slide the controller module out of the chassis and place it on a flat, stable surface.
    Make sure that you support the bottom of the controller module as you slide it out of the chassis.
Step 4: Replace the impaired chassis
Remove the impaired chassis and install the replacement chassis.
Steps
  1. Remove the impaired chassis:
    1. Remove the screws from the chassis mount points.
    2. Slide the impaired chassis off the rack rails in a system cabinet or equipment rack, and then set it aside.
  2. Install the replacement chassis:
    1. Install the replacement chassis into the equipment rack or system cabinet by guiding the chassis onto the rack rails in a system cabinet or equipment rack.
    2. Slide the chassis all the way into the equipment rack or system cabinet.
    3. Secure the front of the chassis to the equipment rack or system cabinet, using the screws you removed from the impaired chassis.
Step 5: Install the chassis components
After the replacement chassis is installed, you need to install the controller module, recable the I/O modules and system management module, and then reinstall and plug in the PSUs.
Steps
  1. Install the controller module:
    1. Align the end of the controller module with the opening in the front of the chassis, and then gently push the controller all the way into the chassis.
    2. Rotate the locking latches into the locked position.
  2. Install the I/O cards at the rear of the chassis:
    1. Align the end of the I/O module with the same slot in the replacement chassis as in the impaired chassis, and then gently push the module all the way into the chassis.
      Note Make sure to install the I/O modules in the same slots as they were in the impaired chassis.
    2. Rotate the cam latch upward into the locked position.
    3. Repeat these steps for any other I/O modules.
  3. Install the system management module at the rear of the chassis:
    1. Align the end of the system management module with the opening in the chassis, and then gently push the module all the way into the chassis.
    3. If you have not already done so, reinstall the cable management device and reconnect the cables to the I/O cards and system management module.
      Note If you removed the media converters (QSFPs or SFPs), remember to reinstall them.
      Make sure that the cables are connected according to the cable labels.
  4. Install the NVRAM12 module in the back of the chassis at the rear of the chassis:
    1. Align the end of the NVRAM12 module with the opening in the chassis, and then gently push the module all the way into the chassis.
  5. Install the PSUs:
    1. Using both hands, support and align the edges of the PSU with the opening in the chassis.
    2. Gently push the PSU into the chassis until the locking tab clicks into place.
      The power supplies will only properly engage with the internal connector and lock in place one way.
      Note To avoid damaging the internal connector, do not use excessive force when sliding the PSU into the system.
  6. Reconnect the PSU power cables to both of the PSUs and secure each power cable to the PSU using the power cable retainer.
    The controller modules begin to boot as soon as PSUs are installed and power is restored.
What's next?
After replacing the impaired AFX 1K chassis and reinstalling its components, complete the chassis replacement.
