Restore and verify the controller configuration in an AFX 1K system
Verify that the controller's HA configuration is active and functioning correctly in your AFX 1K storage system, and confirm that the system's adapters list all the paths to the disks.
Step 1: Verify HA config settings
You must verify the HA state of the controller module and, if necessary, update the state to match your system configuration.
Boot to maintenance mode:
boot_ontap maint-
Enter
ywhen you see Continue with boot?.If you see the System ID mismatch warning message, enter
y.
Enter
sysconfig -vand capture the display contents.If you see PERSONALITY MISMATCH contact customer support. -
From the
sysconfig -voutput, compare the adapter card information with the cards and locations in the replacement controller.
Step 2: Verify disk list
Verify that the adapter lists the paths to all disks:
storage show disk -pIf you see any issues, check cabling and reseat cables.
Exit Maintenance mode:
halt
After restoring and verifying the AFX 1K storage system configuration, give back the controller.
