Add an I/O module to an AFX 1K system
Add an I/O module to your AFX 1K storage system to enhance network connectivity and expand your system's ability to handle data traffic.
You can add an I/O module to your AFX 1K storage system when there are empty slots available or when all slots are fully populated.
Step 1: Shut down the impaired controller module
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Disable automatic giveback from the console of the healthy controller:
storage failover modify –node local -auto-giveback false -
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt (enter system password)
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe
-halt trueparameter brings you to the LOADER prompt.
Step 2: Add the new I/O module
If the storage system has available slots, install the new I/O module into one of the available slots. If all slots are occupied, remove an existing I/O module to make space and then install the new one.
Check the NetApp Hardware Universe to ensure the new I/O module is compatible with your storage system and ONTAP version.
If multiple slots are available, check the slot priorities in NetApp Hardware Universe and use the best one available for your I/O module.
Make sure that all other components are functioning properly.
Make sure you have the replacement component you received from NetApp.
You can add a new I/O module into a storage system with available slots.
If you are not already grounded, properly ground yourself.
Rotate the cable management tray down by pulling the buttons on the inside of the cable management tray and rotating it down.
Remove the target slot blanking module from the carrier:
Depress the cam latch on the blanking module in the target slot.
Rotate the cam latch away from the module as far as it will go.
Remove the module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the enclosure.
Install the I/O module:
Align the I/O module with the edges of the enclosure slot opening.
Gently slide the module into the slot all the way into the enclosure, and then rotate the cam latch all the way up to lock the module in place.
Cable the I/O module to the designated device.
Make sure that any unused I/O slots have blanks installed to prevent possible thermal issues. -
Rotate the cable management tray up to the closed position.
From the LOADER prompt, reboot the node:
byeThis reinitializes the I/O module and other components and reboots the node. -
Press <enter> when console messages stop.
If you see the login prompt, go to the next step.
If you do not see the login prompt, log in to the partner node.
Give back only the root with override-destination-checks option:
storage failover giveback -ofnode impaired-node -only-root true -override -destination-checks trueThe following command is only available in the Diagnostic mode privilege level. For more information on privilege levels, see Understand the privilege levels for ONTAP CLI commands. If you encounter errors, contact NetApp Support.
Wait 5 minutes after the giveback report completes, and check failover status and giveback status:
storage failover showandstorage failover show-givebackThe following command is only available in the Diagnostic mode privilege level. -
If the HA interconnect links were taken down, bring them back up:
system ha interconnect link on -node healthy-node -link 0system ha interconnect link on -node healthy-node -link 1 -
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
Repeat these steps for controller B.
From the healthy node, restore automatic giveback if you disabled it:
storage failover modify -node local -auto-giveback-of true -
If AutoSupport is enabled, restore automatic case creation:
You can add an I/O module to a fully-populated system by removing an existing I/O module and installing a new one in its place.
Make sure you understand the following scenarios for adding a new I/O module to a fully-populated system:
| Scenario | Action required |
NIC to NIC (same number of ports) |
The LIFs will automatically migrate when its controller module is shut down. |
NIC to NIC (different number of ports) |
Permanently reassign the selected LIFs to a different home port. See Migrating a LIF for more information. |
NIC to storage I/O module |
Use System Manager to permanently migrate the LIFs to different home ports, as described in Migrating a LIF. |
Unplug any cabling on the target I/O module.
Remove the target I/O module from the chassis:
Depress the cam latch button.
Make sure that you keep track of which slot the I/O module was in.
Install the I/O module into the target slot in the enclosure:
Align the module with the edges of the enclosure slot opening.
Repeat the remove and install steps to replace additional modules for the controller.
Reboot the controller from the LOADER prompt:_bye_
This reinitializes the PCIe cards and other components and reboots the node.
Enable automatic giveback if it was disabled:
Do one of the following:
If you removed a storage I/O module and installed a new NIC I/O module, use the following network command for each port:
storage port modify -node <node name> -port <port name> -mode network -
If you removed a NIC I/O module and installed a storage I/O module, install and cable your NX224 shelves, as described in Hot-add NX224 shelf.
