Boot the recovery image on an AFX 2K system using the automated boot recovery process
After installing the new boot media device in your AFX 2K storage system, you can start the automated boot media recovery process to restore the configuration from the partner node.
During the recovery process, the system checks whether encryption is enabled and identifies the type of key encryption being used. If key encryption is enabled, the system guides you through the appropriate steps to restore it.
For OKM, you need the cluster-wide passphrase and the backup data.
For EKM, you need copies of the following files from the partner node:
/cfcard/kmip/servers.cfg file.
/cfcard/kmip/certs/client.crt file.
/cfcard/kmip/certs/client.key file.
/cfcard/kmip/certs/CA.pem file.
From the LOADER prompt, enter the command:
boot_recovery -partnerThe screen displays the following message:
Starting boot media recovery (BMR) process. Press Ctrl-C to abort… -
Monitor the boot media install recovery process.
The process completes and displays the
Installation completemessage. -
The system checks for encryption and encryption type and displays one of two messages. Depending on what message is displayed, take one of the following actions:
Occasionally, the process may not be able to identify if key manager is configured on the system. It will display an error message, ask if key manager is configured for the system, and then ask what type of key manager is configured. The process will resume after you resolve the issue. Show example of configuration error finding prompts
Error when fetching key manager config from partner ${partner_ip}: ${status} Has key manager been configured on this system Is the key manager onboardIf you see this message… Do this… key manager is not configured. Exiting.Encryption is not configured on the system. Complete the following steps:
Press <enter> when console messages stop.
If you see the login prompt, go to step 4.
If you do not see login prompt, log into the partner node and proceed to step 4.
Go to step 6 to enable automatic giveback if it was disabled.
key manager is configured.Go to step 5 to restore the appropriate key manager.
The node accesses the boot menu and runs:
Option 10 for systems with Onboard Key Manager (OKM).
Option 11 for systems with External Key Manager (EKM).
If encryption is not installed on the system and the login prompt is not displayed. Complete the following steps:
Give back only the root with override-destination-checks option:
storage failover giveback -ofnode impaired-node -only-root true -override -destination-checks trueThis command is available only in Diagnostic mode. For details, see Privilege levels for ONTAP CLI commands. If you encounter errors, contact NetApp Support.
Wait 5 minutes after the giveback report completes, and check failover status and giveback status:
storage failover showandstorage failover show-givebackThe following command is only available in the Diagnostic mode privilege level. -
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name
For systems with key-manager configured, select the appropriate key manager restoration process.
Onboard Key Manager (OKM)If OKM is detected, the system displays the following message and begins running BootMenu Option 10.
key manager is configured. Entering Bootmenu Option 10... This option must be used only in disaster recovery procedures. Are you sure? (y or n):
Enter
Yat the prompt to confirm you want to start the OKM recovery process. -
Enter the following when prompted:
The passphrase
The passphrase again when prompted to confirm
Backup data for onboard key manager
Show example of passphrase and backup data prompts
Enter the passphrase for onboard key management: -----BEGIN PASSPHRASE----- <passphrase_value> -----END PASSPHRASE----- Enter the passphrase again to confirm: -----BEGIN PASSPHRASE----- <passphrase_value> -----END PASSPHRASE----- Enter the backup data: -----BEGIN BACKUP----- <passphrase_value> -----END ACKUP-----
Continue to monitor the recovery process as it restores the appropriate files from the partner node.
When the recovery process is complete, the node will reboot. The following messages indicate a successful recovery:
Trying to recover keymanager secrets.... Setting recovery material for the onboard key manager Recovery secrets set successfully Trying to delete any existing km_onboard.keydb file. Successfully recovered keymanager secrets.
When the node reboots, verify the boot media recovery was successful by confirming that the system is back online and operational.
storage failover giveback -ofnode impaired_node_name -
After the partner node is fully up and serving data, synchronize the OKM keys across the cluster.
security key-manager onboard sync
External Key Manager (EKM)If EKM is detected, the system displays the following message and begins running BootMenu Option 11.
key manager is configured. Entering Bootmenu Option 11...
Depending on whether the key is successfully restored, take one of the following actions:
If you see
kmip2_client: Successfully imported the keys from external key server: xxx.xxx.xxx.xxx:5696in the output, the EKM configuration has been successfully restored.The process attempts to restore the appropriate files from the partner node and reboots the node. Continue to the next step.
If the key is not successfully restored, the system will halt and indicate that it could not restore the key. The error and warning messages are displayed. You must rerun the recovery process:
boot_recovery -partnerShow example of key recovery error and warning messages
ERROR: kmip_init: halting this system with encrypted mroot... WARNING: kmip_init: authentication keys might not be available. ******************************************************** * A T T E N T I O N * * * * System cannot connect to key managers. * * * ******************************************************** ERROR: kmip_init: halting this system with encrypted mroot... . Terminated Uptime: 11m32s System halting... LOADER-B>
When the node reboots, verify that the boot media recovery was successful by confirming that the system is back online and operational.
Return the controller to normal operation by giving back its storage:
If automatic giveback was disabled, reenable it:
storage failover modify -node local -auto-giveback-of true -
If AutoSupport is enabled, restore automatic case creation:
After you've restored the ONTAP image and the node is up and serving data, you need to return the failed part to NetApp.
