Install and maintain
Learn about adding and replacing I/O modules in an AFX 2K system
Contributors netapp-driley netapp-jsnyder
The AFX 2K storage system offers flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Replacing an I/O module is essential when addressing a failed module.
You can replace a failed I/O module in your AFX 2K storage system with the same type of I/O module, or with a different kind of I/O module. You can also add an I/O module into a system with empty slots.
  • Add an I/O module
    Adding additional modules can improve redundancy, helping to ensure that the system remains operational even if one module fails.
  • Replace an I/O module
    Replacing a failing I/O module can restore the system to its optimal operating state.
I/O slot numbering
The I/O slots on the AFX 2K controller are numbered 1 through 11, as shown in the following illustration.
Slot numbering on an AFX 2K controller
Slot Number I/O Slot Slot Number I/O Slot Slot Number I/O Slot
Callout number 1
HA
Callout number 4
Callout number 5
NVRAM12
Callout number 9
Network
Callout number 2
Cluster
Callout number 6
Callout number 7
NVRAM12-EX
Callout number 10
Storage
Callout number 3
Network
Callout number 8
Storage
Callout number 11
(Optional) Four-port 25GbE SFP28 for additional management connectivity
