Key specifications for an ASA C250 system
The following are select specifications for the ASA C250 storage system in a single high availability pair. Visit NetApp Hardware Universe for the complete specifications for this storage system.
Key specifications for ASA C250
Platform Configuration: ASA C250 Single Chassis HA Pair
Max Raw Capacity: 1.4736 PB
Memory: 128.0000 GB
Form Factor: 2U chassis with 2 HA controllers and 24 drive slots
PCIe Expansion Slots: 4
Minimum ONTAP Version: ONTAP 9.13.1P1
Scaleout maximums
Type: NAS
Type: SAN; HA Pairs: 6; Raw Capacity: 8.8 PB / 7.9 PiB; Max Memory: 768 GB
Type: HA Pair; Raw Capacity: 1.5 PB / 1.3 PiB; Max Memory: 128.0000
I/O
Onboard I/O
Protocol: Ethernet 25 Gbps; Ports: 4
Protocol: Ethernet 10 Gbps; Ports: 4
Total I/O
Protocol: Ethernet 100 Gbps; Ports: 4
Protocol: Ethernet 25 Gbps; Ports: 20
Protocol: FC 32 Gbps; Ports: 16
Protocol: NVMe/FC 32 Gbps; Ports: 16
Ports: 0
Management ports
Protocol: Ethernet 1 Gbps; Ports: 2
Protocol: RS-232 115 Kbps; Ports: 4
Protocol: USB 12 Mbps; Ports: 4
Storage networking supported
FC
iSCSI
NVMe/FC
System environment specifications
Typical Power: 2906 BTU/hr
Worst-case Power: 3750 BTU/hr
Weight: 54.3 lb 24.6 kg
Height: 2U
Width: 19” IEC rack-compliant (17.6” 44.7 cm)
Depth: 21.38" (54.3 cm)
Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation;8% to 80% relative humidity, noncondensing
Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
Acoustic Noise: Declared sound power (LwAd): 7.2 Sound pressure (LpAm) (bystander positions): 69.1 dB
Compliance
Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
Certifications Safety/EMC/EMI: EAC, UKRSEPRO
Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
Standards EMC/EMI: BS-EN-55024, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 14336, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface
Redundant hot-swappable controllers
Redundant hot-swappable power supplies
