Replace the boot media in an ASA C400 system during the automated boot recovery process
The boot media in your ASA C400 system stores essential firmware and configuration data. The replacement process involves removing and opening the controller module, removing the impaired boot media, installing the replacement boot media in the controller module, and then reinstalling the controller module.
The automated boot media recovery process is supported only in ONTAP 9.17.1 and later. If your storage system is running an earlier version of ONTAP, use the manual boot recovery procedure.
The boot media is located inside the controller module under the air duct, and is accessed by removing the controller module from the system.
If you are not already grounded, properly ground yourself.
Release the power cable retainers, and then unplug the cables from the power supplies.
Loosen the hook and loop strap binding the cables to the cable management device, and then unplug the system cables and SFPs (if needed) from the controller module, keeping track of where the cables were connected.
Leave the cables in the cable management device so that when you reinstall the cable management device, the cables are organized.
Remove the cable management device from the controller module and set it aside.
Press down on both of the locking latches, and then rotate both latches downward at the same time.
The controller module moves slightly out of the chassis.
Locking latches
Controller moves slightly out of chassis
Slide the controller module out of the chassis.
Make sure that you support the bottom of the controller module as you slide it out of the chassis.
Place the controller module on a stable, flat surface.
Open the air duct:
Locking tabs
Slide air duct toward back of controller
Rotate air duct up
Press the locking tabs on the sides of the air duct in toward the middle of the controller module.
Slide the air duct toward the back of the controller module, and then rotate it upward to its completely open position.
Locate and remove the boot media from the controller module:
Press blue button
Rotate boot media up and remove from socket
Press the blue button at the end of the boot media until the lip on the boot media clears the blue button.
Rotate the boot media up and gently pull the boot media out of the socket.
Align the edges of the replacement boot media with the boot media socket, and then gently push it into the socket.
Check the boot media to make sure that it is seated squarely and completely in the socket.
If necessary, remove the boot media and reseat it into the socket.
Lock the boot media in place:
Rotate the boot media down toward the motherboard.
Placing a finger at the end of the boot media by the blue button, push down on the boot media end to engage the blue locking button.
While pushing down on the boot media, lift the blue locking button to lock the boot media in place.
Close the air duct.
After physically replacing the impaired boot media, restore the ONTAP image from the partner node.
