Install and maintain
Key specifications for an ASA C400 system
Contributors Grantglass netapp-martyh netapp-jsnyder
The following are select specifications for the ASA C400 storage system in a single high availability pair. Visit NetApp Hardware Universe for the complete specifications for this storage system.
Key specifications for ASA C400
  • Platform Configuration: ASA C400A Single Chassis HA Pair, Ethernet Bundle
  • Max Raw Capacity: 2.9472 PB
  • Memory: 256.0000 GB
  • Form Factor: 4U chassis with 2 HA controllers
  • PCIe Expansion Slots: 10
  • Minimum ONTAP Version: ONTAP 9.13.1P1
Scaleout maximums
  • Type: NAS
  • Type: SAN; HA Pairs: 6; Raw Capacity: 17.7 PB / 15.7 PiB; Max Memory: 1536 GB
  • Type: HA Pair; Raw Capacity: 2.9 PB / 2.6 PiB; Max Memory: 256.0000
I/O
Onboard I/O
  • Protocol: Ethernet 100 Gbps; Ports: 4
  • Protocol: Ethernet 25 Gbps; Ports: 12
Total I/O
  • Protocol: Ethernet 100 Gbps; Ports: 24
  • Protocol: Ethernet 25 Gbps; Ports: 28
  • Protocol: Ethernet 10 Gbps; Ports: 32
  • Protocol: FC 32 Gbps; Ports: 40
  • Protocol: NVMe/FC 32 Gbps; Ports: 40
  • Ports: 0
Management ports
  • Protocol: Ethernet 1 Gbps; Ports: 2
  • Protocol: RS-232 115 Kbps; Ports: 4
  • Protocol: USB 12 Mbps; Ports: 4
Storage networking supported
  • FC
  • iSCSI
  • NVMe/FC
System environment specifications
  • Typical Power: 4209 BTU/hr
  • Worst-case Power: 5215 BTU/hr
  • Weight: 110.0 lb 49.9 kg
  • Height: 4U
  • Width: 19” IEC rack-compliant (17.6” 44.7 cm)
  • Depth: 32.6” (34.7” with cable management bracket)
  • Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation;8% to 80% relative humidity, noncondensing
  • Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
  • Acoustic Noise: Declared sound power (LwAd): 8.5 Sound pressure (LpAm) (bystander positions): 67.2 dB
Compliance
  • Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
  • Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
  • Certifications Safety/EMC/EMI: EAC, UKRSEPRO
  • Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
  • Standards EMC/EMI: BS-EN-55024, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
  • Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 14336, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High availability
  • Ethernet based baseboard management controller (BMC) and ONTAP management interface
  • Redundant hot-swappable controllers
  • Redundant hot-swappable power supplies
  • SAS in-band management over SAS connections
