Install and maintain
Review the requirements for replacing a chassis in an ASA C800 system
Contributors netapp-jsnyder dougthomp
Before replacing the chassis in your ASA C800 system, ensure you meet the necessary requirements for a successful replacement. This includes verifying all other components in the system are functioning properly, verifying that you have local administrator credentials for ONTAP, the correct replacement chassis, and the necessary tools.
The chassis is the physical enclosure housing all the controller components such as the controller/CPU unit, power supply, and I/O.
Review the following requirements.
  • Make sure all other components in the system are functioning properly; if not, contact NetApp support for assistance.
  • Obtain local administrator credentials for ONTAP if you don't have them.
  • Make sure that you have the necessary tools and equipment for the replacement.
  • You can use the chassis replacement procedure with all versions of ONTAP supported by your system.
  • The chassis replacement procedure is written with the assumption that you are moving the bezel, NVMe drives, and controller modules to the new chassis, and that the replacement chassis is a new component from NetApp.
  • The chassis replacement procedure is disruptive. For a two-node cluster, you will have a complete service outage and a partial outage in a multi-node cluster.
What's next?
After reviewing the requirements, prepare to replace the chassis.
