Review the requirements for replacing a controller in an ASA A70 or ASA A90 system
Before replacing the controller in your ASA A70 or ASA A90 system, ensure you meet the necessary requirements for a successful replacement. This includes verifying all other components in the system are functioning properly, verifying that you have the correct replacement controller, and saving the controller's console output to a text log file.
Review the requirements for replacing the controller module.
NetApp strongly recommends that you enable console logging on the devices you are working with and take the following actions when performing this procedure:
All drive shelves must be working properly.
The healthy controller must be able to take over the controller that is being replaced (referred to in this procedure as the “impaired controller”).
Do not use this procedure for controller upgrades; instead, refer to the Choose your controller hardware upgrade procedure for guidance.
If your system is in a MetroCluster configuration, you must review Choosing the correct recovery procedure to determine whether you should use this procedure.
You must replace the failed component with the field-replaceable unit (FRU) you received from NetApp.
You must replace a controller module with a controller module of the same model type. You cannot upgrade your system by just replacing the controller module.
You cannot change any drives or drive shelves as part of this procedure.
Because the boot device is located on the System Management module that is installed in the back of the system, you do not need to move the boot device when replacing a controller module.
It is important that you apply the commands in these steps on the correct systems:
The impaired controller is the controller that is being replaced.
The replacement controller is the new controller that is replacing the impaired controller.
The healthy controller is the surviving controller.
