Hot-swap an SSD drive in an ASA A70 or ASA A90 system
Hot-swap a drive in your ASA A70 or ASA A90 system when a drive fails or requires an upgrade. This process involves identifying the faulty drive, safely removing it, and installing a new drive to ensure continued data access and system performance.
When a drive fails, the platform logs a warning message to the system console indicating which drive has failed. In addition, both the fault LED on the operator display panel and the fault LED on the failed drive are illuminated.
Follow best practice and install the current version of the Disk Qualification Package (DQP) before replacing a drive.
Identify the failed disk drive by running the
storage disk show -brokencommand from the system console.The failed drive appears in the list of failed drives. If it does not, you should wait, and then run the command again.
It can take up to several hours for the drive to appear in the list of failed drives.
Determine whether SED authentication is enabled.
How you replace the disk depends on how the disk drive is being used. If SED authentication is enabled, you must use the SED replacement instructions in the ONTAP 9 NetApp Encryption Power Guide. These instructions describe additional steps you must perform before and after replacing an SED.
Make sure the replacement drive is supported by your platform. See NetApp Hardware Universe.
Make sure all other components in the system are functioning properly; if not, you must contact technical support.
Drive firmware is automatically updated (nondisruptively) on new drives that have non-current firmware versions.
When replacing several disk drives, you must wait 70 seconds between the removal of each failed disk drive and the insertion of the replacement disk drive to allow the storage system to recognize the existence of each new disk.
You manually assign drive ownership and then reenable automatic drive assignment later in this procedure.
Properly ground yourself.
Remove the bezel from the front of the storage system.
Physically identify the failed drive.
When a drive fails, the system logs a warning message to the system console indicating which drive failed. Additionally, the attention (amber) LED on the shelf operator display panel and the failed drive illuminate.
The activity (green) LED on a failed drive can be illuminated (solid), which indicates that the drive has power, but should not be blinking, which indicates I/O activity. A failed drive has no I/O activity.
Remove the failed drive:
Press the release button on the drive face to open the cam handle.
Rotate the cam handle downward to disengage the drive from the midplane.
Slide the drive out of the drive bay using the cam handle and supporting the drive with your other hand.
When removing a drive, always use two hands to support its weight.
Because drives are fragile, minimize handling to avoid damaging them.
Wait a minimum of 70 seconds before inserting the replacement drive.
This allows the system to recognize that a drive was removed.
Insert the replacement drive:
With the cam handle in the open position, use both hands to insert the replacement drive.
Gently push until the drive stops.
Close the cam handle so that the drive is fully seated into the midplane and the handle clicks into place.
Be sure to close the cam handle slowly so that it aligns correctly with the face of the drive.
Verify that the drive's activity (green) LED is illuminated.
When the drive's activity LED is solid, it means that the drive has power. When the drive's activity LED is blinking, it means that the drive has power and I/O is in progress. If the drive firmware is automatically updating, the LED blinks.
If you are replacing another drive, repeat Steps 3 through 7.
Reinstall the bezel on the front of the storage system.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
Contact technical support NetApp Support if you need the RMA number or additional help with the replacement procedure.
