Install and maintain
Complete the chassis replacement for an ASA A1K system
Contributors netapp-jsnyder dougthomp
Reboot the controller, verify system health, and return the failed part to NetApp to complete the final step in the ASA A1K chassis replacement procedure.
Step 1: Boot the controllers and verify system health
After the controllers reboot, boot ONTAP, give back the controllers, and verify the storage system health.
Steps
  1. Check the console output:
    1. If the controller boots to the LOADER prompt, reboot the controller with the boot_ontap command.
    2. If the console displays waiting for giveback after the reboot, log into the partner controller and check that the replaced controller is ready for giveback with the storage failover show command.
  2. Perform the giveback:
    1. Connect the console cable to the partner controller.
    2. Return the impaired controller to normal operation by giving back its storage: storage failover giveback -ofnode impaired_node_name
    3. If automatic giveback was disabled, reenable it: storage failover modify -node impaired_node_name -auto-giveback true
    4. If AutoSupport is enabled, restore/unsuppress automatic case creation: system node autosupport invoke -node * -type all -message MAINT=END
  3. After the giveback is complete, run Active IQ Config Advisor to verify the health of the storage system and correct any issues you encounter.
Step 2: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
