Install and maintain
Boot media replacement workflow for an ASA A20, ASA A30, or ASA A50 system using the automated boot recovery process
Contributors netapp-jsnyder netapp-lisa
Get started with replacing the boot media in your ASA A30, ASA A20, or ASA A50 storage system by reviewing the replacement requirements, shutting down the impaired controller, replacing the boot media, restoring the image on the boot media, and verifying the system functionality.
Review the requirements for boot media replacement.
Shut down or take over the impaired controller so that the healthy controller continues to serve data from the impaired controller storage.
Remove the failed boot media from the impaired controller and install the replacement boot media.
Restore the ONTAP image from the healthy controller.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
