Complete the chassis replacement for an ASA A20, ASA A30, or ASA A50 system
Verify the HA state of the chassis and then return the failed part to NetApp to complete the final step in the ASA A20, ASA A30, and ASA A50 chassis replacement procedure.
Step 1: Verify and set the HA state of the chassis
You must verify the HA state of the chassis, and, if necessary, update the state to match your storage system configuration.
In Maintenance mode, from either controller, display the HA state of the local controller and chassis:
ha-config showThe HA state should be the same for all components.
If the displayed system state for the chassis does not match your storage system configuration:
Set the HA state for the chassis:
ha-config modify chassis HA-stateThe value for HA-state should be ha. The value for HA-state can be one of the following: * ha * mcc (not supported in ASA)
Confirm that the setting has changed:
ha-config show
If you have not already done so, recable the rest of your storage system.
Step 2: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
