Learn about I/O modules in an ASA A20, ASA A30, or ASA A50 system
The ASA A20, ASA A30, and ASA A50 storage systems offer flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding, hot-swapping or replacing an I/O module is essential when upgrading network capabilities or addressing a failed module.
You can replace a failed I/O module in your storage system with the same type of I/O module, or with a different type of I/O module. You can hot-swap a cluster and HA I/O module when your storage system meets specific requirements. You can also add an I/O module to a storage system with available slots.
Adding additional I/O modules can improve redundancy, helping to ensure that the storage system remains operational even if one I/O module fails.
You can hot-swap certain I/O modules for an equivalent I/O module to restore the storage system to its optimal operating state. Hot-swapping is done without having to perform a manual takeover.
To use this procedure, your storage system must be running ONTAP 9.17.1 or later and meet specific system requirements.
Replacing a failing I/O module can restore the storage system to its optimal operating state.
