Install and maintain
Replace the chassis in an ASA C30 system
Contributors netapp-jsnyder netapp-lisa
Replace the chassis of your ASA C30 storage system when a hardware failure requires it. The replacement process involves removing the controllers, removing the drives, installing the replacement chassis, and reinstalling the chassis components.
About this task
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the system location-led on command.
A storage system has three location LEDs: one on the operator display panel and one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the system location-led off command. If you are unsure if the LEDs are on or off, you can check their state by entering the system location-led show command.
Step 1: Remove the controller
You must remove the controller from the chassis when you replace the controller or replace a component inside the controller.
Before you begin
Make sure all other components in the storage system are functioning properly; if not, you must contact NetApp Support before continuing with this procedure.
Steps
  1. On the impaired controller, make sure the NV LED is off.
    When the NV LED is off, destaging is complete and it is safe to remove the impaired controller.
    Note If the NV LED is flashing (green), destage is in progress. You must wait for the NV LED to turn off. However, if the flashing continues for longer than five minutes, contact NetApp Support before continuing with this procedure.
    The NV LED is located next to the NV icon on the controller.
    NV status LED location
Callout number 1
NV icon and LED on the controller
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
  1. Disconnect the power on the impaired controller:
    Note Power supplies (PSUs) do not have a power switch.
    If you are disconnecting a…​ Then…​
    AC PSU
    1. Open the power cord retainer.
    2. Unplug the power cord from the PSU and set it aside.
    DC PSU
    1. Unscrew the two thumb screws on the D-SUB DC power cord connector.
  2. Unplug all cables from the impaired controller.
    Keep track of where the cables were connected.
  3. Remove the impaired controller:
    The following illustration shows the operation of the controller handles (from the left side of the controller) when removing a controller:
    controller handle operation to remove a controller
    Callout number 1
    On both ends of the controller, push the vertical locking tabs outward to release the handles.
    Callout number 2
    • Pull the handles towards you to unseat the controller from the midplane.
      As you pull, the handles extend out from the controller and then you feel some resistance, keep pulling.
    • Slide the controller out of the chassis while supporting the bottom of the controller, and place it on a flat, stable surface.
    Callout number 3
    If needed, rotate the handles upright (next to the tabs) to move them out of the way.
  4. Repeat these steps for the other controller in the chassis.
Step 2: Remove the drives from the impaired chassis
You need to remove all of the drives and any drive blanks from the impaired chassis so that later in the procedure you can install them in the replacement chassis.
  1. Gently remove the bezel from the front of the storage system.
  2. Remove the drives and any drive blanks:
    Note Keep track of what drive bay each drive and drive blank was removed from because they must be installed in the same drive bays in the replacement chassis.
    Remove NVMe drive
    Callout number 1
    Press the release button on the drive face to open the cam handle.
    Callout number 2
    Rotate the cam handle downward to disengage the drive from the midplane.
    Callout number 3
    Slide the drive out of the drive bay using the cam handle and supporting the drive with your other hand.
    When removing a drive, always use two hands to support its weight.
    Note Because drives are fragile, minimize handling to avoid damaging them.
  3. Set the drives aside on a static-free cart or table.
Step 2: Replace the chassis from within the equipment rack or system cabinet
You remove the impaired chassis from the equipment rack or system cabinet, install the replacement chassis, install the drives, any drive blanks, and then install the bezel.
  1. Remove the screws from the impaired chassis mount points.
    Set the screws aside to use later in this procedure.
    Note If the storage system shipped in a NetApp system cabinet, you must remove additional screws at the rear of the chassis before the chassis can be removed.
  2. Using two people or a power lift, remove the impaired chassis from the equipment rack or system cabinet by sliding it off the rails, and then set it aside.
  3. Using two people, install the replacement chassis into the equipment rack or system cabinet by sliding it onto the rails.
  4. Secure the front of the replacement chassis to the equipment rack or system cabinet using the screws you removed from the impaired chassis.
Step 4: Install the controllers and drives
Install the controllers and drives into the replacement chassis and reboot the controllers.
About this task
The following illustration shows the operation of the controller handles (from the left side of a controller) when installing a controller, and can be used as a reference for the rest of the controller installation steps.
controller handle operation to install a controller
Callout number 1
If you rotated the controller handles upright (next to the tabs) to move them out of the way, rotate them down to the horizontal position.
Callout number 2
Push the handles to reinsert the controller into the chassis and push until the controller is fully seated.
Callout number 3
Rotate the handles to the upright position and lock in place with the locking tabs.
  1. Insert one of the controllers into the chassis:
    1. Align the back of the controller with the opening in the chassis.
    2. Firmly push on the handles until the controller meets the midplane and is fully seated in the chassis.
      Note Do not use excessive force when sliding the controller into the chassis; it could damage the connectors.
    3. Rotate the controller handles up and lock in place with the tabs.
  2. Recable the controller, as needed, except for the power cords.
  3. Repeat these steps to install the second controller into the chassis.
  4. Install the drives and any drive blanks you removed from the impaired chassis into the replacement chassis:
    Note The drives and drive blanks must be installed in the same drive bays in the replacement chassis.
    1. With the cam handle in the open position, use both hands to insert the drive.
    2. Gently push until the drive stops.
    3. Close the cam handle so that the drive is fully seated into the midplane and the handle clicks into place.
      Be sure to close the cam handle slowly so that it aligns correctly with the face of the drive.
    4. Repeat the process for the remaining drives.
  5. Install the bezel.
  6. Reconnect the power cords to the power supplies (PSU) in the controllers.
    Once power is restored to a PSU, the status LED should be green.
    Note The controllers begin to boot as soon as the power is restored.
    If you are reconnecting a…​ Then…​
    AC PSU
    1. Plug the power cord into the PSU.
    2. Secure the power cord with the power cord retainer.
    DC PSU
    1. Plug the D-SUB DC power cord connector into the PSU.
    2. Tighten the two thumb screws to secure the D-SUB DC power cord connector to the PSU.
  7. If controllers boot to the LOADER prompt, reboot the controllers:
    boot_ontap
  8. Turn AutoSupport back on:
What's next?
After you’ve replaced the impaired chassis and reinstalled the components into it, you need to complete the chassis replacement.
