Key specifications for an ASA A1K system
The following are select specifications for the ASA A1K storage system in a single high availability pair. Visit NetApp Hardware Universe (HWU) for the complete specifications for this storage system.
Key capacity, memory, form factor, and ONTAP Version specifications
Platform Configuration: ASA A1KA Dual Chassis HA Pair
Max Raw Capacity: 2.6622 PB
Memory: 2048.0000 GB
Form Factor: 2U chassis with 1 HA controllers
PCIe Expansion Slots: 18
Minimum ONTAP Version: ONTAP 9.16.0
Scaleout maximums
Type: NAS
Type: SAN; HA Pairs: 6; Raw Capacity: 16.0 PB / 14.2 PiB; Max Memory: 12288 GB
Type: HA Pair; Raw Capacity: 2.7 PB / 2.4 PiB; Max Memory: 2048.0000
I/O
Onboard I/O
No onboard I/O data.
Total I/O
Protocol: Ethernet 200 Gbps; Ports: 24
Protocol: Ethernet 100 Gbps; Ports: 36
Protocol: Ethernet 25 Gbps; Ports: 56
Protocol: Ethernet 10 Gbps; Ports: 56
Protocol: FC 64 Gbps; Ports: 56
Protocol: NVMe/FC 64 Gbps; Ports: 56
Ports: 0
Management ports
Protocol: Ethernet 1 Gbps; Ports: 2
Protocol: RS-232 115 Kbps; Ports: 4
Protocol: USB 600 Mbps; Ports: 2
Storage networking supported
FC
iSCSI
NVMe/FC
NVMe/TCP
System environment specifications
Typical Power: 4402 BTU/hr
Worst-case Power: 6174 BTU/hr
Weight: 59.5 lb 27.0 kg
Height: 2U
Width: 19” IEC rack-compliant (17.7” 44.9 cm)
Depth: 30.0” (35.2” with cable management bracket)
Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation; 8% to 80% relative humidity, noncondensing
Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
Acoustic Noise: Declared sound power (LwAd): 8.5 Sound pressure (LpAm) (bystander positions): 67.7 dB
Compliance
Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
Certifications Safety/EMC/EMI: EAC, UKRSEPRO
Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface
Redundant hot-swappable controllers
Redundant hot-swappable power supplies
SAS in-band management over SAS connections for external shelves
