Install and maintain
Key specifications for an ASA A30 system
Contributors netapp-martyh Grantglass netapp-jsnyder
The following are select specifications for the ASA A30 storage system in a single high availability pair. Visit NetApp Hardware Universe (HWU) for the complete specifications for this storage system.
Key capacity, memory, form factor, and ONTAP Version specifications
  • Platform Configuration: ASA A30 Single Chassis HA Pair
  • Max Raw Capacity: 1.1016 PB
  • Memory: 128.0000 GB
  • Form Factor: 2U chassis with 2 HA controllers and 24 drive slots
  • PCIe Expansion Slots: 8
  • Minimum ONTAP Version: ONTAP 9.16.1
Scaleout maximums
  • Type: NAS
  • Type: SAN; HA Pairs: 4; Raw Capacity: 4.4 PB / 3.9 PiB; Max Memory: 512 GB
  • Type: HA Pair; Raw Capacity: 1.1 PB / 1.0 PiB; Max Memory: 128.0000
I/O
Onboard I/O
No onboard I/O data.
Total I/O
  • Protocol: Ethernet 100 Gbps; Ports: 16
  • Protocol: Ethernet 25 Gbps; Ports: 24
  • Protocol: Ethernet 10 Gbps; Ports: 24
  • Protocol: FC 64 Gbps; Ports: 24
  • Protocol: NVMe/FC 64 Gbps; Ports: 24
  • Ports: 0
Management ports
  • Protocol: Ethernet 1 Gbps; Ports: 2
  • Protocol: RS-232 115 Kbps; Ports: 4
  • Protocol: USB 600 Mbps; Ports: 2
Storage networking supported
  • FC
  • iSCSI
  • NVMe/FC
  • NVMe/TCP
System environment specifications
  • Typical Power: 2892 BTU/hr
  • Worst-case Power: 4445 BTU/hr
  • Weight: 60.7 lb 27.5 kg
  • Height: 2U
  • Width: 19” IEC rack-compliant (17.6” 44.7 cm)
  • Depth:
  • Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation; 8% to 80% relative humidity, noncondensing
  • Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
  • Acoustic Noise: Declared sound power (LwAd): 8.0 Sound pressure (LpAm) (bystander positions): 70.5 dB
Compliance
  • Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
  • Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
  • Certifications Safety/EMC/EMI: EAC, UKRSEPRO
  • Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
  • Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
  • Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
  • This product is ENERGY STAR Certified. For more information, visit ENERGY STAR certified data center storage products.
    ENERGY STAR certified logo
High availability
  • Ethernet based baseboard management controller (BMC) and ONTAP management interface
  • Redundant hot-swappable controllers
  • Redundant hot-swappable power supplies
  • SAS in-band management over SAS connections for external shelves
