Check encryption support on the boot media in an AFF C30 or AFF C60 system
To ensure data security on your AFF C30 or AFF C60 storage system, you need to verify the encryption key support and status on your boot media. Check if your ONTAP version supports NetApp Volume Encryption (NVE). Before you shut down the controller, check if the key manager is active.
Step 1: Check NVE support and download the correct ONTAP image
Determine whether your ONTAP version supports NetApp Volume Encryption (NVE) so you can download the correct ONTAP image for the boot media replacement.
Check if your ONTAP version supports encryption:
version -vIf the output includes
1Ono-DARE, NVE is not supported on your cluster version. -
Download the appropriate ONTAP image based on NVE support:
If NVE is supported: Download the ONTAP image with NetApp Volume Encryption
If NVE is not supported: Download the ONTAP image without NetApp Volume Encryption
Download the ONTAP image from the NetApp Support Site to your HTTP or FTP server or a local folder. You will need this image file during the boot media replacement procedure.
Step 2: Verify key manager status and back up configuration
Before shutting down the controller with the impaired boot media, verify the key manager configuration and back up the necessary information.
Determine which key manager is enabled on your system:
ONTAP version Run this command ONTAP 9.14.1 or later
security key-manager keystore show-
If EKM is enabled,
EKMis listed in the command output. -
If OKM is enabled,
OKMis listed in the command output. -
If no key manager is enabled,
No key manager keystores configuredis listed in the command output.
ONTAP 9.13.1 or earlier
security key-manager show-key-store-
If EKM is enabled,
externalis listed in the command output. -
If OKM is enabled,
onboardis listed in the command output. -
No key managers configuredis listed in the command output.
Depending on whether a key manager is configured on your system, do one of the following:
If no key manager is configured:
You can safely shut down the impaired controller and proceed to the shutdown procedure.
If a key manager is configured (EKM or OKM):
Enter the following query command to display the status of the authentication keys in your key manager:
security key-manager key query -
Review the output and check the value in the
Restoredcolumn. This column indicates whether the authentication keys for your key manager (either EKM or OKM) have been successfully restored.
Complete the appropriate procedure based on your key manager type:
External Key Manager (EKM)Complete these steps based on the value in the
Restoredcolumn.If all keys show
truein the Restored column:You can safely shut down the impaired controller and proceed to the shutdown procedure.
If any keys show a value other than
truein the Restored column:-
Restore the external key management authentication keys to all nodes in the cluster:
security key-manager external restoreIf the command fails, contact NetApp Support.
Verify that all authentication keys are restored:
security key-manager key queryConfirm that the
Restoredcolumn displaystruefor all authentication keys. -
If all keys are restored, you can safely shut down the impaired controller and proceed to the shutdown procedure.
Onboard Key Manager (OKM)Complete these steps based on the value in the
Back up the OKM information:
Switch to advanced privilege mode:
set -priv advancedEnter
ywhen prompted to continue. -
Display the key management backup information:
security key-manager onboard show-backup -
Copy the backup information to a separate file or your log file.
You will need this backup information if you need to manually recover OKM during the replacement procedure.
Return to admin mode:
set -priv admin
Synchronize the onboard key manager:
security key-manager onboard syncEnter the 32-character alphanumeric onboard key management passphrase when prompted.
This is the cluster-wide passphrase you created when you initially configured the Onboard Key Manager. If you do not have this passphrase, contact NetApp Support. -
Verify all authentication keys are restored:
Restoredcolumn displaystruefor all authentication keys and theKey Managertype showsonboard. -
set -priv admin
After checking the encryption key support and status on the boot media, you need to shut down the controller.
