Install and maintain
Review the requirements for replacing a controller in an AFF C30 or AFF C60 system
Contributors netapp-jsnyder netapp-lisa
Before replacing the controller in your AFF C30 or AFF C60 storage system, confirm that you meet the necessary requirements for a successful replacement. This includes verifying that all other components in the system are functioning properly, verifying that you have the correct replacement controller, and saving the controller's console output to a text log file.
Review the requirements and considerations for the controller replacement procedure.
Note
NetApp strongly recommends that you enable console logging on the devices you are working with and take the following actions when performing this procedure:
  • Leave AutoSupport enabled during your maintenance. This allows NetApp support to receive diagnostic information if issues occur.
  • Enable session logging for any CLI sessions. This creates a complete record of all commands and system output during the maintenance activity. For guidance on how to enable session logging, see How to configure PuTTY for optimal connectivity to ONTAP systems.
Requirements
  • All shelves must be working properly.
  • The healthy controller must be able to take over the controller that is being replaced (referred to in this procedure as the “impaired controller”).
  • If your system is in a MetroCluster configuration, you must review the section Choosing the correct recovery procedure to determine whether you should use this procedure.
  • You must replace a controller with a controller of the same model type. You cannot upgrade your system by just replacing the controller.
  • You cannot change any drives or shelves as part of this procedure.
Considerations
It is important that you apply the commands in this procedure to the correct controller:
  • The impaired controller is the controller that is being replaced.
  • The replacement controller is the new controller that is replacing the impaired controller.
  • The healthy controller is the surviving controller.
What's next?
After you’ve reviewed the requirements to replace the impaired controller, you need to shut down the impaired controller.
