Install and maintain
Key specifications for C30-60 platform group
Contributors netapp-martyh netapp-jsnyder Grantglass
The following are select specifications for the C30-60 platform group. Visit NetApp Hardware Universe (HWU) for a complete list of specifications. This page is reflective of a single high availability pair.
AFF C60
Key specifications for AFF C60
Platform Configuration: AFF C60 Single Chassis HA Pair
Max Raw Capacity: 7.3680 PB
Memory: 128.0000 GB
Form Factor: 2U chassis with 2 HA controllers and 24 drive slots
ONTAP Version: b_startONTAP: 9.16.1P2b_end
PCIe Expansion Slots: 8
Minimum ONTAP Version: ONTAP 9.16.1RC1
Scaleout Maximums
Type
HA Pairs
Raw Capacity
Max Memory
NAS
4
29.5 PB / 26.2 PiB
512 GB
SAN
4
29.5 PB / 26.2 PiB
512 GB
HA Pair
7.4 PB / 6.5 PiB
128.0000
IO
Onboard IO
No onboard IO data.
Total IO
Protocol
Ports
Ethernet 100 Gbps
16
Ethernet 25 Gbps
24
Ethernet 10 Gbps
24
FC 64 Gbps
24
NVMe/FC 64 Gbps
24
0
Management Ports
Protocol
Ports
Ethernet 1 Gbps
2
RS-232 115 Kbps
4
USB 600 Mbps
2
Storage Networking Supported
CIFS; FC; iSCSI; NFS v3; NFS v4.0; NFS v4.1; NFS v4.2; NVMe/FC ; NVMe/TCP; S3; S3 with NAS; SMB 2.0; SMB 2.1; SMB 2.x; SMB 3.0; SMB 3.1; SMB 3.1.1;
System Environment Specifications
  • Typical Power: 2892 BTU/hr
  • Worst-case Power: 4445 BTU/hr
  • Weight: 60.7 lb 27.5 kg
  • Height: 2U
  • Width: 19" IEC rack-compliant (17.6" 44.7 cm)
  • Depth:
  • Operating Temp/Altitude/Humidity: 10°C to 35°C (50°F to 95°F) at up to 3048m (10000 ft) elevation;8% to 80% relative humidity, noncondensing
  • Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) up to 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
  • Acoustic Noise: Declared sound power (LwAd): 8.0; Sound pressure (LpAm) (bystander positions): 70.5 dB
Compliance
  • Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
  • Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
  • Certifications Safety/EMC/EMI: EAC, UKRSEPRO
  • Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
  • Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
  • Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High Availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface; Redundant hot-swappable controllers; Redundant hot-swappable power supplies;
AFF C30
Key specifications for AFF C30
Platform Configuration: AFF C30 Single Chassis HA Pair
Max Raw Capacity: 2.2104 PB
Memory: 128.0000 GB
Scaleout Maximums
Type
HA Pairs
Raw Capacity
Max Memory
NAS
4
8.8 PB / 7.9 PiB
512 GB
SAN
4
8.8 PB / 7.9 PiB
512 GB
HA Pair
2.2 PB / 2.0 PiB
128.0000
IO
Onboard IO
No onboard IO data.
Total IO
Protocol
Ports
Ethernet 100 Gbps
16
Ethernet 25 Gbps
24
Ethernet 10 Gbps
24
FC 64 Gbps
24
NVMe/FC 64 Gbps
24
0
Management Ports
Protocol
Ports
Ethernet 1 Gbps
2
RS-232 115 Kbps
4
USB 600 Mbps
2
  • Height: 2U
  • Depth:
Compliance
High Availability
