Hot-swap a power supply unit in an AFF C30 or AFF C60 system
Replace an AC or DC power supply unit (PSU) in your AFF C30 or AFF C60 storage system when it fails or becomes faulty, so your system continues to receive the required power for stable operation. The replacement process involves disconnecting the faulty PSU from the power source, unplugging the power cord, replacing the faulty PSU, and then reconnecting it to the power source.
This procedure is written for replacing one PSU at a time.
The PSUs are redundant and hot-swappable. You do not have to shut down the controller to replace a PSU.
IMPORTANT: Do not mix PSUs with different efficiency ratings or different input types. Always replace like for like.
Use the appropriate procedure for your type of PSU: AC or DC.
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the
system location-led oncommand.A storage system has three location LEDs: one on the operator display panel and one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the
system location-led offcommand. If you are unsure if the LEDs are on or off, you can check their state by entering thesystem location-led showcommand.
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
To replace an AC PSU, complete the following steps.
Identify the faulty PSU based on console error messages or through the red Attention LED on the PSU.
Disconnect the power cord from the PSU by opening the power cord retainer, and then unplug the power cord from the PSU.
PSUs do not have a power switch. -
Remove the PSU:
Rotate the PSU handle up, to its horizontal position, and then grasp it.
With your thumb, press the blue tab to release the PSU from the controller.
Pull the PSU out of the controller while using your other hand to support its weight.
The PSU is short. Always use two hands to support it when removing it from the controller so that it does not suddenly swing free from the controller and injure you. -
Install the replacement PSU:
Using both hands, support and align the edges of the PSU with the opening in the controller.
Gently push the PSU into the controller until the locking tab clicks into place.
A PSU will only properly engage with the internal connector and lock in place one way.
To avoid damaging the internal connector, do not use excessive force when sliding the PSU into the controller. -
Rotate the handle down, so it is out of the way of normal operations.
Reconnect the power cord to the PSU and secure the power cord with the power cord retainer.
Once power is restored to the PSU, the status LED should be green.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
To replace a DC PSU, complete the following steps.
If you are not already grounded, properly ground yourself.
Disconnect the PSU:
Unscrew the two thumb screws on the D-SUB DC power cord connector.
The illustration and table in step 4 shows the two thumb screws (item #1) and the D-SUB DC power cord connector (item #2).
Unplug the cord from the PSU and set it aside.
Remove the PSU:
Rotate the handle up, to its horizontal position, and then grasp it.
With your thumb, press the terracotta tab to release the locking mechanism.
The PSU is short. Always use two hands to support it when removing it from the controller so that it does not swing free from the controller and injure you.
Thumb screws
D-SUB DC power PSU cord connector
Power supply handle
Terracotta PSU locking tab
Insert the replacement PSU:
Gently slide the PSU into the controller until the locking tab clicks into place.
A PSU must properly engage with the internal connector and locking mechanism. Repeat this step if you feel the PSU is not properly seated.
Reconnect the D-SUB DC power cord:
Plug the D-SUB DC power cord connector into the PSU.
Tighten the two thumb screws to secure the D-SUB DC power cord connector to the PSU.
