Install and maintain
Cabling worksheets for DS212C, DS224C, or DS460C shelves with internal storage platforms
Contributors netapp-ivanad netapp-jsnyder netapp-lisa
You can use the completed controller-to-stack cabling worksheets and cabling examples to cable platforms with internal storage. This applies to shelves with IOM12, IOM12B, or IOM12C modules.
  • If needed, you can refer to SAS cabling rules and concepts for information about supported configurations, shelf-to-shelf connectivity, and controller-to-shelf connectivity.
  • Cabling examples show controller-to-stack cables as solid or dashed to distinguish controller 0b/0b1 port connections from controller 0a port connections.
    Cable type key for platforms with onboard storage
  • Cabling examples show controller-to-stack connections and shelf-to-shelf connections in two different colors to distinguish connectivity through IOM A (domain A) and IOM B (domain B).
    Cable color key for platforms with onboard storage
FAS2820 platform in a multipath HA configuration with no external shelves
The following example shows that no cabling is needed to acheive multipath HA connectivity:
FAS2820 multipath HA with no external shelves
FAS2820 platform in a tri-path HA configuration with no external shelves
The following cabling example shows required cabling between the two controllers to achieve tri-path connectivity:
Fas2800 Tri path HA cabling example with no external shelves
FAS2820 platform in a tri-path HA configuration with one multi-shelf stack
The following worksheet and cabling example uses port pair 0a/0b1:
FAS2820 tri path HA cabling worksheet showing port pairs for stack 1
FAS2820 tri path HA cabling example to one stack
Platforms with internal storage in a multipath HA configuration with one multi-shelf stack
The following worksheet and cabling example uses port pair 0a/0b:
Note This section does not apply to FAS2820 systems.
Multipath HA cabling worksheet for platforms with internal storage and one stack
Multipath HA cabling example for platforms with internal storage
