Install and maintain
Cabling worksheets for DS212C, DS224C, or DS460C multipath HA configurations
Contributors netapp-ivanad netapp-lisa
You can use the controller-to-stack cabling worksheets and cabling examples to cable your HA pair as a multipath HA configuration.
This applies to shelves with IOM12, IOM12B, or IOM12C modules.
Note This information applies to platforms without internal storage.
  • If needed, you can refer to SAS cabling rules and concepts for information about supported configurations, the controller slot numbering convention, shelf-to-shelf connectivity, and controller-to-shelf connectivity (including the use of port pairs).
  • If needed, you can refer to How to read a worksheet to cable controller-to-stack connections for multipathed connectivity.
  • Cabling examples show controller-to-stack cables as solid or dashed to distinguish controller A and C port connections from controller B and D port connections.
    Multipath HA configuration cable type key
  • Cables in the cabling examples and their corresponding port pairs in the worksheets are color-coded to distinguish connectivity to each stack in the HA pair.
    Multipath HA configuration cable color key
  • Worksheets and cabling examples show cabling port pairs in the order in which they are listed in the worksheet.
Controller-to-stack cabling worksheets and cabling examples for multipath HA configurations with quad-port SAS HBAs
You can use the completed controller-to-stack cabling worksheets and cabling examples to cable common multipath HA configurations that have quad-port SAS HBAs. These controllers do not have onboard SAS ports.
Multipath HA with one quad-port SAS HBA and one single-shelf stack
The following worksheet and cabling example uses port pair 1a/1d:
Multipath HA cabling worksheet for one quad port SAS HBA and one single shelf stack
Multipath HA cabling example for one quad port SAS HBA and one single shelf stack
Multipath HA with one quad-port SAS HBA and two single-shelf stacks
The following worksheet and cabling example uses port pairs 1a/1d and 1c/1b:
Multipath HA cabling worksheet for one quad port SAS HBA and two single shelf stacks
Multipath HA cabling example for one quad port SAS HBA and two single shelf stacks
Multipath HA with two quad-port SAS HBAs and two multi-shelf stacks
Four port pairs are available for this configuration: 1a/2b, 2a/1d, 1c/2d, and 2c/1b. You can cable port pairs in the order in which they are identified (listed in the worksheet) or you can cable every other port pair (skip port pairs).
Note When you have more port pairs than you need to cable the stacks in your system, the best practice is to skip port pairs to optimize the SAS ports on your system. By optimizing SAS ports, you optimize your system's performance.
The following worksheet and cabling example shows port pairs being used in the order in which they are listed in the worksheet: 1a/2b, 2a/1d, 1c/2d, and 2c/1b.
Multipath HA cabling worksheet for two quad port SAS HBAs and two multi shelf stacks
Multipath HA cabling example for two quad port SAS HBAs and two multi shelf stacks
The following worksheet and cabling example shows port pairs being skipped to use every other one in the list: 1a/2b and 1c/2d.
Note If a third stack is added later, you use the port pair that was skipped.
Multipath HA cabling worksheet for two quad port SAS HBAs and two multi shelf stacks using skipped port pairs
Multipath HA cabling example for two quad port SAS HBAs and two multi shelf stacks using skipped port pairs
Controller-to-stack cabling worksheets and cabling examples for multipath HA configurations with four onboard SAS ports
You can use the completed controller-to-stack cabling worksheets and cabling examples to cable common multipath HA configurations that have four onboard SAS ports.
Multipath HA with four onboard SAS ports and one single-shelf stack
The following worksheet and cabling example uses port pair 0a/0d:
Multipath HA cabling worksheet for four onboard ports and one single shelf stack
Multipath HA cabling example for four onboard ports and one single shelf stack
Multipath HA with four onboard SAS ports and two single-shelf stacks
The following worksheet and cabling example uses port pairs 0a/0d and 0c/0b:
Multipath HA cabling worksheet for four onboard ports and two single shelf stacks
Multipath HA cabling example for four onboard ports and two single shelf stacks
Multipath HA with four onboard SAS ports, a quad-port SAS HBA, and two multi-shelf stacks
Four port pairs are available for this configuration: 0a/1b, 1a/0d, 0c/1d, and 1c/0b. You can cable port pairs in the order in which they are identified (listed in the worksheet) or you can cable every other port pair (skip port pairs).
The following worksheet and cabling example shows port pairs being used in the order in which they are listed in the worksheet: 0a/1b, 1a/0d, 0c/1d, and 1c/0b.
Multipath HA cabling worksheet for four onboard SAS ports a quad port SAS HBA and two multi shelf stacks
Multipath HA cabling example for four onboard SAS ports a quad port SAS HBA and two multi shelf stacks
The following worksheet and cabling example shows port pairs being skipped to use every other one in the list: 0a/1b and 0c/1d.
Multipath HA cabling worksheet for four onboard ports a quad port SAS HBA and two multi shelf stacks using skipped port pairs
Multipath HA cabling example for four onboard ports a quad port SAS HBA and two multi shelf stacks using skipped port pairs
