Install NX-OS software and Reference Configuration Files (RCFs)
Contributors Download PDF of this page
Install NX-OS software and RCF on a Cisco Nexus 9336C- FX2 cluster switch
The Cisco NX-OS software and reference configuration file (RCF) must be installed on Cisco Nexus 9336C-FX2 cluster switches.
Before you begin
The following conditions must exist before you install the NX-OS software and RCF on the cluster switch:
  • The cluster must be fully functioning (there should be no errors in the logs or similar issues).
  • You must have checked or set your desired boot configuration in the RCF to reflect the desired boot images if you are installing only NX-OS and keeping your current RCF version.
  • If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
  • You must have a console connection to the switch, required when installing the RCF.
  • You must have consulted the switch compatibility table on the Cisco Ethernet switch page for the supported ONTAP, NX-OS, and RCF versions.
    See Cisco Ethernet Switches for more information.
  • There can be command dependencies between the command syntax in the RCF and that found in versions of NX-OS.
  • You must have referred to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures on Cisco Nexus 9000 Series Switches.
    See Cisco Nexus 9000 Series Switches for more information.
  • You must have the current RCF.
Initial setup
The examples in this procedure use two nodes. These nodes use two 100GbE cluster interconnect ports e3a and e3b, as per the A400 controller.
See the Hardware Universe to verify the correct cluster ports on your platforms.
Note The command outputs might vary depending on different releases of ONTAP.
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are cluster1-01 and cluster1-02.
  • The cluster LIF names are cluster1-01_clus1 and cluster1-01_clus2 for cluster1-01 and cluster1-02_clus1 and cluster1-02_clus2 for cluster1-02.
  • The cluster1::*> prompt indicates the name of the cluster.
Note The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all -message MAINT=x h
    Where x is the duration of the maintenance window in hours.
  1. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  2. Display how many cluster interconnect interfaces are configured in each node for each cluster interconnect switch:
    network device-discovery show -protocol cdp
cluster1:: network device-discovery show -protocol cdp
Node/       Local  Discovered
Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
cluster1-02/cdp
            e3a    cs1                       Eth1/2            N9K-C9336C
            e3b    cs2                       Eth1/2            N9K-C9336C
cluster1-01/cdp
            e3a    cs1                       Eth1/1            N9K-C9336C
            e3b    cs2                       Eth1/1            N9K-C9336C
4 entries were displayed.
  1. Check the administrative or operational status of each cluster interface:
    1. Display the network port attributes:
      network port show –ipspace Cluster
cluster1::*> network port show -ipspace Cluster
Node: cluster1-02
                                                  Speed(Mbps)  Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper   Status
e3a       Cluster      Cluster          up   9000  auto/100000 healthy
e3b       Cluster      Cluster          up   9000  auto/100000 healthy
Node: cluster1-01
                                                  Speed(Mbps)  Health
  1. Display information about the LIFs:
    network interface show - vserver Cluster
cluster1::*> network interface show -vserver Cluster
        Logical            Status     Network            Current    Current Is
Vserver Interface          Admin/Oper Address/Mask       Node        Port   Home
Cluster
        cluster1-01_clus1  up/up      169.254.209.69/16  cluster1-01  e3a   true
        cluster1-01_clus2  up/up      169.254.49.125/16  cluster1-01  e3b   true
        cluster1-02_clus1  up/up      169.254.47.194/16  cluster1-02  e3a   true
        cluster1-02_clus2  up/up      169.254.19.183/16  cluster1-02  e3b   true
  1. Ping the remote cluster LIFs:
    cluster ping-cluster -node node-name
cluster1::*> cluster ping-cluster -node cluster1-02
Host is cluster1-02
Getting addresses from network interface table...
Cluster cluster1-01_clus1 169.254.209.69 cluster1-01     e3a
Cluster cluster1-01_clus2 169.254.49.125 cluster1-01     e3b
Cluster cluster1-02_clus1 169.254.47.194 cluster1-02     e3a
Cluster cluster1-02_clus2 169.254.19.183 cluster1-02     e3b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
    Local 169.254.19.183 to Remote 169.254.209.69
    Local 169.254.19.183 to Remote 169.254.49.125
    Local 169.254.47.194 to Remote 169.254.209.69
    Local 169.254.47.194 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
  1. Verify that the auto-revert command is enabled on all cluster LIFs:
    network interface show - vserver Cluster -fields auto-revert
cluster1::*> network interface show -vserver Cluster -fields auto-revert
          Logical
Vserver   Interface            Auto-revert
Cluster
          cluster1-01_clus1    true
          cluster1-01_clus2    true
          cluster1-02_clus1    true
          cluster1-02_clus2    true
  1. Enable the Ethernet switch health monitor log collection feature for collecting switch-related log files, using the following commands:
    • system switch ethernet log setup-password
    • system switch ethernet log enable-collection
cluster1::*> system switch ethernet log setup password
Enter the switch name: <return>
The switch name entered is not recognized.
Choose from the following list:
cs1
cs2
cluster1::*> system switch ethernet log setup-password
Enter the switch name: cs1
RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc
Do you want to continue? {y|n}::[n] y
Enter the password: <enter switch password>
Enter the password again: <enter switch password>
Enter the switch name: cs2
RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1
Do you want to continue? {y|n}:: [n] y
cluster1::*> system  switch ethernet log enable-collection
Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y
Enabling cluster switch log collection.
cluster1::*>
Note If any of these commands return an error, contact NetApp support.
Install the NX-OS software on a Cisco Nexus 9336C- FX2 cluster switch
You can use this procedure to install the NX-OS software on the Cisco Nexus 9336C-FX2 cluster switch.
Steps
  1. Connect the cluster switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
cs2# ping 172.19.2.1
Pinging 172.19.2.1 with 0 bytes of data:
Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  1. Copy the NX-OS software and EPLD images to the Nexus 9336C-FX2 switch.
cs2# copy sftp: bootflash: vrf management
Enter source filename: /code/nxos.9.3.5.bin
Enter hostname for the sftp server: 172.19.2.1
Enter username: user1
Outbound-ReKey for 172.19.2.1:22
Inbound-ReKey for 172.19.2.1:22
user1@172.19.2.1's password:
sftp> progress
Progress meter enabled
sftp> get   /code/nxos.9.3.5.bin  /bootflash/nxos.9.3.5.bin
/code/nxos.9.3.5.bin  100% 1261MB   9.3MB/s   02:15
sftp> exit
Copy complete, now saving to disk (please wait)...
Copy complete.
Enter source filename: /code/n9000-epld.9.3.5.img
sftp> progress
sftp> get   /code/n9000-epld.9.3.5.img  /bootflash/n9000-epld.9.3.5.img
/code/n9000-epld.9.3.5.img  100%  161MB   9.5MB/s   00:16
sftp> exit
Copy complete.
  1. Verify the running version of the NX-OS software:
    show version
cs2# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2020, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
  BIOS: version 08.38
  NXOS: version 9.3(4)
  BIOS compile time:  05/29/2020
  NXOS image file is: bootflash:///nxos.9.3.4.bin
  NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 02:28:31]
Hardware
  cisco Nexus9000 C9336C-FX2 Chassis
  Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory.
  Processor Board ID FOC20291J6K
  Device name: cs2
  bootflash:   53298520 kB
Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 42 second(s)
Last reset at 157524 usecs after Mon Nov  2 18:32:06 2020
  Reason: Reset Requested by CLI command reload
  System version: 9.3(4)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Active Package(s):
cs2#
  1. Install the NX-OS image.
Note Installing the image file causes it to be loaded every time the switch is rebooted.
cs2# install all nxos bootflash:nxos.9.3.5.bin
Installer will perform compatibility check first. Please wait.
Installer is forced disruptive
Verifying image bootflash:/nxos.9.3.5.bin for boot variable "nxos".
[####################] 100% -- SUCCESS
Verifying image type.
Preparing "nxos" version info using image bootflash:/nxos.9.3.5.bin.
Preparing "bios" version info using image bootflash:/nxos.9.3.5.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable       Impact     Install-type  Reason
  1       yes      disruptive         reset     default upgrade is not hitless
Images will be upgraded according to following table:
Module   Image    Running-Version(pri:alt                New-Version         Upg-
        Required
  1      nxos     9.3(4)                                 9.3(5)              yes
  1      bios     v08.37(01/28/2020):v08.23(09/23/2015)  v08.38(05/29/2020)  yes
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)?  [n] y
Install is in progress, please wait.
Performing runtime checks.
Setting boot variables.
Performing configuration copy.
Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
Warning: please do not remove or power off the module at this time.
Finishing the upgrade, switch will reboot in 10 seconds.
  1. Verify the new version of NX-OS software after the switch has rebooted:
    show version
cs2# show version
Software
  BIOS: version 05.33
  NXOS: version 9.3(5)
  BIOS compile time:  09/08/2018
  NXOS image file is: bootflash:///nxos.9.3.5.bin
  NXOS compile time:  11/4/2018 21:00:00 [11/05/2018 06:11:06]
Hardware
  Device name: cs2
Last reset at 277524 usecs after Mon Nov  2 22:45:12 2020
  Reason: Reset due to upgrade
  Service:
plugin
Active Package(s):
  1. Upgrade the EPLD image and reboot the switch.
cs2# show version module 1 epld
EPLD Device                     Version
MI   FPGA                        0x7
IO   FPGA                        0x17
MI   FPGA2                       0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
cs2# install epld bootflash:n9000-epld.9.3.5.img module 1
Compatibility check:
Module      Type        Upgradable  Impact      Reason
     1      SUP        Yes          disruptive  Module Upgradable
Retrieving EPLD versions.... Please wait.
Module  Type   EPLD              Running-Version   New-Version  Upg-Required
     1  SUP    MI FPGA           0x07              0x07         No
     1  SUP    IO FPGA           0x17              0x19         Yes
     1  SUP    MI FPGA2          0x02              0x02         No
The above modules require upgrade.
The switch will be reloaded at the end of the upgrade
Do you want to continue (y/n) ?  [n] y
Proceeding to upgrade Modules.
Starting Module 1 EPLD Upgrade
Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
Module 1 EPLD upgrade is successful.
Module   Type  Upgrade-Result
     1   SUP   Success
EPLDs upgraded.
  1. After the switch reboot, log in again and verify that the new version of EPLD loaded successfully.
EPLD Device                     Version
MI   FPGA                        0x7
IO   FPGA                        0x19
MI   FPGA2                       0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
GEM  FPGA                        0x2
Install the RCF on a Cisco Nexus 9336C- FX2 cluster switch
You can install the RCF after setting up the Nexus 9336C-FX2 cluster switch for the first time. You can also use this procedure to upgrade your RCF version on your cluster switch.
About this task
  • The node names are cluster1-01, cluster1-02, cluster1-03, and cluster1-04.
  • The cluster LIF names are cluster1-01_clus1, cluster1-01_clus2, cluster1-02_clus1, cluster1-02_clus2, cluster1-03_clus1, cluster1-03_clus2, cluster1-04_clus1, and cluster1-04_clus2.
Steps
  1. Display the cluster ports on each node that are connected to the cluster switches:
cluster1::*> network device-discovery show
cluster1-01/cdp
            e3a    cs1                       Ethernet1/7       N9K-C9336C
            e0d    cs2                       Ethernet1/7       N9K-C9336C
cluster1-02/cdp
            e3a    cs1                       Ethernet1/8       N9K-C9336C
            e0d    cs2                       Ethernet1/8       N9K-C9336C
cluster1-03/cdp
            e3a    cs1                       Ethernet1/1/1     N9K-C9336C
            e3b    cs2                       Ethernet1/1/1     N9K-C9336C
cluster1-04/cdp
            e3a    cs1                       Ethernet1/1/2     N9K-C9336C
            e3b    cs2                       Ethernet1/1/2     N9K-C9336C
cluster1::*>
  1. Check the administrative and operational status of each cluster port.
  2. Verify that all the cluster ports are up with a healthy status:
    network port show –role cluster
cluster1::*> network port show -role cluster
Node: cluster1-01
        Ignore
                                                  Speed(Mbps) Health   Health
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
e3a       Cluster      Cluster          up   9000  auto/100000 healthy false
e0d       Cluster      Cluster          up   9000  auto/100000 healthy false
Node: cluster1-02
        Ignore
8 entries were displayed.
Node: cluster1-03
        Ignore
e3b       Cluster      Cluster          up   9000  auto/100000 healthy  false
Node: cluster1-04
        Ignore
e0a       Cluster      Cluster          up   9000  auto/100000 healthy  false
e0b       Cluster      Cluster          up   9000  auto/100000 healthy  false
cluster1::*>
  1. Verify that all the cluster interfaces (LIFs) are on the home port:
    network interface show -role cluster
cluster1::*> network interface show -role cluster
Cluster
        cluster1-01_clus1  up/up     169.254.3.4/23   cluster1-01  e3a     true
        cluster1-01_clus2  up/up     169.254.3.5/23   cluster1-01  e0d     true
        cluster1-02_clus1  up/up     169.254.3.8/23   cluster1-02  e3a     true
        cluster1-02_clus2  up/up     169.254.3.9/23   cluster1-02  e0d     true
        cluster1-03_clus1  up/up     169.254.1.3/23   cluster1-03  e3a     true
        cluster1-03_clus2  up/up     169.254.1.1/23   cluster1-03  e3b     true
        cluster1-04_clus1  up/up     169.254.1.6/23   cluster1-04  e3a     true
        cluster1-04_clus2  up/up     169.254.1.7/23   cluster1-04  e3b     true
cluster1::*>
  1. Verify that the cluster displays information for both cluster switches:
    system cluster-switch show -is-monitoring-enabled-operational true
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
Switch                      Type               Address          Model
cs1                         cluster-network    10.233.205.90    N9K-C9336C
     Serial Number: FOCXXXXXXGD
      Is Monitored: true
            Reason: None
  Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                    9.3(5)
    Version Source: CDP
cs2                         cluster-network    10.233.205.91    N9K-C9336C
     Serial Number: FOCXXXXXXGS
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
cluster1::*>
  1. Disable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
  1. On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
cs2(config)# interface eth1/1/1-2,eth1/7-8
cs2(config-if-range)# shutdown
  1. Verify that the cluster LIFs have migrated to the ports hosted on cluster switch cs1. This might take a few seconds:
Cluster
        cluster1-01_clus2 up/up     169.254.3.5/23   cluster1-01   e3a     false
        cluster1-02_clus2 up/up     169.254.3.9/23   cluster1-02   e3a     false
        cluster1-03_clus2 up/up     169.254.1.1/23   cluster1-03   e3a     false
        cluster1-04_clus2 up/up     169.254.1.7/23   cluster1-04   e3a     false
cluster1::*>
  1. Verify that the cluster is healthy:
    cluster show
cluster1::*> cluster show
Node                 Health  Eligibility   Epsilon
cluster1-01          true    true          false
cluster1-02          true    true          false
cluster1-03          true    true          true
cluster1-04          true    true          false
cluster1::*>
  1. Clean the configuration on switch cs2 and perform a basic setup.
    1. Clean the configuration. This step requires a console connection to the switch.
cs2# write erase
Warning: This command will erase the startup-configuration.
Do you wish to proceed anyway? (y/n)  [n] y
cs2# reload
This command will reboot the system. (y/n)?  [n] y
cs2#
  1. Perform a basic setup of the switch.
  1. Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information about Cisco commands, see the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
    This example shows TFTP being used to copy an RCF to the bootflash on switch cs2.
cs2# copy tftp: bootflash: vrf management
Enter source filename: Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt
Enter hostname for the tftp server: 172.22.201.50
Trying to connect to tftp server......Connection to Server Established.
TFTP get operation was successful
  1. Apply the RCF previously downloaded to the bootflash.
    This example shows the RCF file Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt being installed on switch cs2.
cs2# copy Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
  1. Examine the banner output from the show banner motd command. You must read and follow these instructions to ensure the proper configuration and operation of the switch.
cs2# show banner motd
* NetApp Reference Configuration File (RCF)
* Switch   : Nexus N9K-C9336C-FX2
* Filename : Nexus_9336C_RCF_v1.6-Cluster-HA-Breakout.txt
* Date     : 10-23-2020
* Version  : v1.6
* Port Usage:
* Ports  1- 3: Breakout mode (4x10G) Intra-Cluster Ports, int e1/1/1-4,
* e1/2/1-4, e1/3/1-4
* Ports  4- 6: Breakout mode (4x25G) Intra-Cluster/HA Ports, int e1/4/1-4,
* e1/5/1-4, e1/6/1-4
* Ports  7-34: 40/100GbE Intra-Cluster/HA Ports, int e1/7-34
* Ports 35-36: Intra-Cluster ISL Ports, int e1/35-36
* Dynamic breakout commands:
* 10G: interface breakout module 1 port <range> map 10g-4x
* 25G: interface breakout module 1 port <range> map 25g-4x
* Undo breakout commands and return interfaces to 40/100G configuration in
* config mode:
* no interface breakout module 1 port <range> map 10g-4x
* no interface breakout module 1 port <range> map 25g-4x
* interface Ethernet <interfaces taken out of breakout mode>
* inherit port-profile 40-100G
* priority-flow-control mode auto
* service-policy input HA
* exit
  1. Verify that the RCF file is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  2. After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
cs2# copy running-config startup-config [########################################] 100% Copy complete
  1. Reboot switch cs2. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
cs2# reload
  1. Apply the same RCF and save the running configuration for a second time.
  1. Verify the health of cluster ports on the cluster.
    1. Verify that e0d ports are up and healthy across all nodes in the cluster:
Node: cluster1-01
        Ignore
Node: cluster1-02
        Ignore
Node: cluster1-03
        Ignore
Node: cluster1-04
        Ignore
  1. Verify the switch health from the cluster (this might not show switch cs2, since LIFs are not homed on e0d).
cluster1::*> network device-discovery show -protocol cdp
cluster1-01/cdp
cluster01-2/cdp
cluster01-3/cdp
cluster1-04/cdp
cs1                         cluster-network    10.233.205.90    NX9-C9336C
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
cs2                         cluster-network    10.233.205.91    NX9-C9336C
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
2 entries were displayed.
Note You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch.
2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored.
2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan.
2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
  1. On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes. The following example uses the interface example output from step 1:
cs1(config)# interface eth1/1/1-2,eth1/7-8
cs1(config-if-range)# shutdown
  1. Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds:
Cluster
        cluster1-01_clus1  up/up       169.254.3.4/23   cluster1-01   e0d  false
        cluster1-02_clus1  up/up       169.254.3.8/23   cluster1-02   e0d  false
        cluster1-03_clus1  up/up       169.254.1.3/23   cluster1-03   e3b  false
        cluster1-04_clus1  up/up       169.254.1.6/23   cluster1-04   e3b  false
cluster1::*>
    cluster show
cluster1::*>
  1. Repeat Steps 7 to 14 on switch cs1.
  2. Enable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
  1. Reboot switch cs1. You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the “cluster ports down” events reported on the nodes while the switch reboots.
cs1# reload
  1. Verify that the switch ports connected to the cluster ports are up.
cs1# show interface brief | grep up
Eth1/1/1      1       eth  access up      none                   100G(D) --
Eth1/1/2      1       eth  access up      none                   100G(D) --
Eth1/7        1       eth  trunk  up      none                   100G(D) --
Eth1/8        1       eth  trunk  up      none                   100G(D) --
  1. Verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
cs1# show port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        b - BFD Session Wait
        S - Switched    R - Routed
        U - Up (port-channel)
        p - Up in delay-lacp mode (member)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports      Channel
1     Po1(SU)     Eth      LACP      Eth1/35(P)        Eth1/36(P)
cs1#
  1. Verify that the cluster LIFs have reverted to their home port:
Cluster
        cluster1-01_clus1  up/up      169.254.3.4/23    cluster1-01  e0d   true
        cluster1-02_clus1  up/up      169.254.3.8/23    cluster1-02  e0d   true
        cluster1-03_clus1  up/up      169.254.1.3/23    cluster1-03  e3b   true
        cluster1-04_clus1  up/up      169.254.1.6/23    cluster1-04  e3b   true
cluster1::*>
    cluster show
cluster1::*>
  1. Ping the remote cluster interfaces to verify connectivity:
    cluster ping-cluster -node local
cluster1::*> cluster ping-cluster -node local
Host is cluster1-03
Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e3a
Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e3b
Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e3a
Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e3b
Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e3a
Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d
Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e3a
Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d
Local = 169.254.1.3 169.254.1.1
Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9
Ping status:
Basic connectivity succeeds on 12 path(s)
Detected 9000 byte MTU on 12 path(s):
    Local 169.254.1.3 to Remote 169.254.1.6
    Local 169.254.1.3 to Remote 169.254.1.7
    Local 169.254.1.3 to Remote 169.254.3.4
    Local 169.254.1.3 to Remote 169.254.3.5
    Local 169.254.1.3 to Remote 169.254.3.8
    Local 169.254.1.3 to Remote 169.254.3.9
    Local 169.254.1.1 to Remote 169.254.1.6
    Local 169.254.1.1 to Remote 169.254.1.7
    Local 169.254.1.1 to Remote 169.254.3.4
    Local 169.254.1.1 to Remote 169.254.3.5
    Local 169.254.1.1 to Remote 169.254.3.8
    Local 169.254.1.1 to Remote 169.254.3.9
Larger than PMTU communication succeeds on 12 path(s)
RPC status:
6 paths up, 0 paths down (tcp check)
6 paths up, 0 paths down (udp check)
Install the RCF on a Cisco Nexus 9336C-FX2 storage switch
The reference configuration files (RCFs) can be upgraded on Cisco Nexus 9336C-FX2 storage switches.
Before you begin
The following conditions must exist before you upgrade the RCF on the storage switch:
  • The switch must be fully functioning (there should be no errors in the logs or similar issues).
  • You must have checked or set your desired boot variables in the RCF to reflect the desired boot images if you are installing only NX-OS and keeping your current RCF version.
  • If you need to change the boot variables to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
  • You must have referred to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco storage upgrade and downgrade procedures. See Cisco Nexus 9000 Series Switches for more information.
  • The number of 100 GbE ports are defined in the reference configuration files (RCFs) available on the Cisco Ethernet switches page.
Procedure summary
  1. Check the health status of switches and ports (steps 1-4)
  2. Download the NX-OS image to Cisco switch st2 and reboot (steps 5-8)
  3. Copy the RCF to Cisco switch st2 (steps 9-12)
  4. Recheck the health status of switches and ports (steps 13-15)
  5. Repeat steps 1-15 for Cisco switch st1.
  • The names of the two storage switches are st1 and st2.
  • The nodes are node1 and node2.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message: system node autosupport invoke -node * -type all - message MAINT=xh
  2. Check that the storage switches are available:
    system switch ethernet show
storage::*> system switch ethernet show
st1
                          storage-network    172.17.227.5     NX9-C9336C
      Serial Number: FOC221206C2
       Is Monitored: true
             Reason: None
                     9.3(5)
     Version Source: CDP
st2
                          storage-network    172.17.227.6     NX9-C9336C
      Serial Number: FOC220443LZ
       Is Monitored: true
             Reason: None
                     9.3(5)
     Version Source: CDP
storage::*>
  1. Verify that the node ports are healthy and operational:
    storage port show -port-type ENET
storage::*> storage port show -port-type ENET
                                   Speed                            VLAN
Node     Port   Type    Mode       (Gb/s)     State     Status        ID
node1
        e3a     ENET    storage    100        enabled   online         30
        e3b     ENET    storage      0        enabled   offline        30
        e7a     ENET    storage      0        enabled   offline        30
        e7b     ENET    storage    100        enabled   online         30
node2
  1. Check that there are no storage switch or cabling issues with the cluster:
    system health alert show -instance
storage::*> system health alert show -instance
There are no entries matching your query.
  1. Download the NX-OS image to switch st2.
  2. Install the system image so that the new version will be loaded the next time switch st2 is rebooted. The switch will be reboot in 10 seconds with the new image as shown in the following output:
st2# install all nxos bootflash:nxos.9.3. 5.bin
Verifying image bootflash:/nxos.9.3.4.bin for boot variable "nxos".
[[####################] 100% -- SUCCESS
Preparing "nxos" version info using image bootflash:/nxos.9.3.4.bin.
Preparing "bios" version info using image bootflash:/nxos.9.3.4.bin.
Module Image        Running-Version(pri:alt)               New-Version  Upg
        Required
 1     nxos                                     9.3(3)          9.3(4)       yes
 1     bios      v08.37(01/28/2020):v08.23(09/23/2015)   v08.38(05/29/2020)   no
input string too long
st2#
  1. Save the configuration.
    You are prompted to reboot the system as shown in the following example:
st2# copy running-config startup-config
[########################################] 100% Copy complete.
st2# reload
  1. Confirm that the new NX-OS version number is on the switch.
st2# show version
Upgrading a Cisco Nexus 9336C Storage Switch 6
Upgrading a Cisco Nexus 9336C storage switch
licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose.
Software
 BIOS: version 08.38
 NXOS image file is: bootflash:///nxos.9.3. 5.bin
Hardware
 cisco Nexus9000 C9336C Chassis (Nexus 9000 Series)
 Device name: S2
   System version: 9.3(5)
   Service:
plugin
   Active Package(s):
st2#
  1. Copy the RCF on switch st2 to the switch bootflash using one of the following transfer protocols: FTP, HTTP, TFTP, SFTP, or SCP.
    The following example shows HTTP being used to copy an RCF to the bootflash on switch st2:
st2# copy http://172.16.10.1//cfg/Nexus_9336C_RCF_v1.6-Storage.txt bootflash: vrf management
% Total % Received % Xferd   Average   Speed  Time   Time   Time
Current
   Dload     Upload  Total Spent   Left
Speed
 100    3254          100     3254      0       0     8175    0 --:--:-- --:--:-- --:--:–
8301
Copy complete.
st2#
  1. Apply the RCF previously downloaded to the bootflash:
    copy bootflash.
    The following example shows the RCF file Nexus_9336C_RCF_v1.6-Storage.txt being installed on switch st2:
st2# copy Nexus_9336C_RCF_v1.6-Storage.txt running-config echo-commands
    show running-config
    • The RCF banner
    • Customizations
      Important: In the banner output from the show banner motd command, you must read and follow the instructions in the *IMPORTANT NOTES *section to ensure the proper configuration and operation of the switch.
st2# show banner motd
*NetApp Reference Configuration File (RCF)
*Switch : Nexus N9K-C9336C-FX2
*Filename : Nexus_9336C_RCF_v1.6-Storage.txt
* Date : 10-23-2020
*Version  : v1.6
*Port Usage: Storage configuration
*Ports 1-36: 100GbE Controller and Shelf Storage Ports
*IMPORTANT NOTES*
*- This RCF utilizes QoS and requires TCAM re-configuration, requiring RCF
*to be loaded twice with the Storage Switch rebooted in between.
*- Perform the following 4 steps to ensure proper RCF installation:
*(1) Apply RCF first time, expect following messages:
*- Please save config and reload the system...
*- Edge port type (portfast) should only be enabled on ports...
*- TCAM region is not configured for feature QoS class IPv4 ingress...
*(2) Save running-configuration and reboot Cluster Switch
*(3) After reboot, apply same RCF second time and expect following messages:
*- % Invalid command at '^' marker
*- Syntax error while parsing...
*(4) Save running-configuration again
st2#
  1. After you verify that the software versions and switch settings are correct, copy the running-config file to the startup-config file on switch st2.
    For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference guides.
    The following example shows the running-config file successfully copied to the startup-config file:
  1. Recheck that the storage switches are available after the reboot:
st1
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
st2
      Is Monitored: true
            Reason: None
                    9.3(5)
    Version Source: CDP
storage::*
  1. Verify that the switch ports are healthy and operational after the reboot:
                                   Speed                            VLAN
node1
node2
  1. Recheck that there is no storage switch or cabling issues with the cluster:
  1. Repeat this procedure for the RCF on switch st1.
  2. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
Install the RCF on a Cisco Nexus 9336C-FX2 shared switch
From ONTAP 9.9.1, you can use Cisco Nexus 9336C-FX2 switches to combine storage and cluster functionality into a shared switch scenario.
Before you begin
  • The cluster switches must be fully functioning (there should be no errors in the logs or similar issues).
  • The storage switches must be fully functioning (there should be no errors in the logs or similar issues).
  • The names of the two storage switches are sh1 and sh2.
  • The example used here loads the shared RCF on to the new switch.
Steps
  1. Copy the RCF on switch sh2 to the switch bootflash using one of the following transfer protocols: FTP, HTTP, TFTP, SFTP, or SCP.
    The following example shows HTTP being used to copy an RCF to the bootflash on switch sh2:
sh2# copy http://172.16.10.1//cfg/Nexus_9336C_RCF_v1.7-Cluster-Ha-Storage.txt bootflash: vrf management
Current
Speed
 100    5143          100     5143      0       0     11300    0 --:--:-- --:--:-- --:--:–
11300
Copy complete.
sh2#
    copy bootflash.
    The following example shows the RCF file `Nexus_9336C_RCF_v1.7-Cluster-HA-Storage.txt ` being installed on switch sh2:
sh2# copy Nexus_9336C_RCF_v1.7-Cluster-HA-Storage.txt running-config echo-commands
  1. Verify that the RCF file is the correct newer version: show running-config
    • The RCF banner
    • Customizations
sh2# show banner motd
*Filename : Nexus_9336C_RCF_v1.7-Cluster-HA-Storage.txt
* Date :  Jan-08-2021
*Version  : v1.7
*Port Usage:
*Ports  1-8: 40/100GbE Intra-Cluster/HA Ports, int e1/1-8
*Port     9: 10GbE breakout Intra-Cluster Ports, int e1/9/1-4
*Port    10: 25GbE breakout Intra-Cluster/HA Ports, int e1/10/1-4
*Ports 11-22: First HA-pair Controller and Shelf Storage Ports, int e1/11-22
*Ports 23-34: Second HA-pair Controller and Shelf Storage Ports, int e1/23-34
*Ports 35-36: Intra-Cluster ISL Ports, int e1/35-36
* config mode:
* no interface breakout module 1 port 9 map 10g-4x
* no interface breakout module 1 port 10 map 25g-4x
* interface Ethernet 1/9-10
* inherit port-profile CLUSTER_HA
* service-policy type qos input HA_POLICY
* exit
*IMPORTANT NOTES*
* In certain conditions, N9K-C9336C-FX2 may not be able to auto-negotiate port
* speed correctly, and port speed must be manually set, in config mode, e.g.
* int e1/1
* speed 40000
* int e1/3
* speed 100000
sh2#
  1. After you verify that the software versions and switch settings are correct, copy the running-config file to the startup-config file on switch sh2.
sh2# copy running-config startup-config
  1. Repeat this procedure for the RCF on switch sh1.
