Check for MetroCluster configuration errors
Contributors netapp-barbe
You can use the Config Advisor tool available from the NetApp Support Site to check for common configuration errors.
About this task
Config Advisor is a configuration validation and health check tool. You can deploy it at both secure sites and non-secure sites for data collection and system analysis.
Support for Config Advisor is limited, and available only online.
  1. Download the Active IQ Config Advisor tool.
  2. Run Active IQ Config Advisor, reviewing the output and following its recommendations to address any issues.
