Decide whether to use the aggregate relocation guide
Contributors netapp-barbe
This guide describes how to upgrade the storage controllers in an HA pair with new controllers while keeping all the existing data and disks. This is a complex procedure that should be used only by experienced administrators.
You should use this guide under the following circumstances:
  • You are running ONTAP 9.8.
  • You do not want to add the new controllers as a new HA pair to the cluster and migrate the data using volume moves.
  • You are experienced in administering ONTAP and are comfortable with the risks of working in the diagnostic privilege mode.
  • If you are upgrading a MetroCluster configuration, it is a 4-node or higher FC configuration, and all nodes are running ONTAP 9.8.
For upgrading MetroCluster IP configurations, refer to the MetroCluster Upgrade, Transition, and Expansion Guide.
You can use NetApp Storage Encryption (NSE) and NetApp Volume Encryption (NVE) with this procedure.
The following table shows the supported model matrix for the controller upgrade.
Old controller Replacement controller
FAS8020, FAS8040, FAS8060, FAS8080
FAS8200, FAS8300, FAS8700, FAS9000
AFF8020, AFF8040, AFF8060, AFF8080
AFF A300, AFF A400, AFF A700, AFF A800*
FAS8200
FAS8700, FAS9000, FAS8300
AFF A300
AFF A700, AFF A800*, AFF A400
If your controller upgrade model combination is not in the above table, contact technical support.
If you prefer a different method of upgrading the controller hardware and are willing to do volume moves, use the Controller Hardware Upgrade Express Guide instead. See the ONTAP 9 Documentation Center to access ONTAP 9 product documentation.
