Move non-root aggregates and NAS data LIFs owned by node1 from node2 to node3
After you verify network configuration on node3 and before you relocate aggregates from node2 to node3, you must verify that the NAS data LIFs belonging to node1 that are currently on node2 are relocated from node2 to node3. You must also verify that the SAN LIFs exist on node3.
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports. You will verify that the LIFs are healthy and located on appropriate ports after you bring node3 online.
Resume the relocation operation by using the following command:
system controller replace resume
The system performs the following tasks:
Cluster quorum check
System ID check
Image version check
Target platform check
Network reachability check
The operation pauses at this stage in the network reachability check.
The system performs the following checks:
Cluster health check
Cluster LIF status check
After performing these checks, the system relocates the non-root aggregates and NAS data LIFs owned by node1 to the new controller, node3.
The controller replacement operation pauses after the resource relocation is complete. -
Check the status of the aggregate relocation and NAS data LIF move operations by using the following command:
system controller replace show-details
If the controller replacement procedure is paused, check and correct the error, if any, and then issue
resume
to continue the operation. -
If necessary, restore and revert any displaced LIFs. List any displaced LIFs by using the following command:
cluster controller-replacement network displaced-interface show
If any LIFs are displaced, restore the home node back to node3 by using the following command:
cluster controller-replacement network displaced-interface restore-home-node
Resume the operation to prompt the system to perform the required post-checks by using the following command:
The system performs the following post-checks:
Aggregates reconstruction check
Aggregate status check
Disk status check
Volume check
