Relocate non-root aggregates and NAS data LIFs owned by node1 to node2
Before you can replace node1 with node3, you must move the non-root aggregates and NAS data LIFs from node1 to node2 before eventually moving node1’s resources to node3.
The operation should already be paused when you begin the task; you must manually resume the operation.
After the aggregates and LIFs are migrated, the operation is paused for verification purposes. At this stage, you must verify whether or not all the non-root aggregates and non-SAN data LIFs are migrated to node3.
The home owner for the aggregates and LIFs are not modified; only the current -owner is modified. |
Resume the aggregate relocation and NAS data LIF move operations by using the following command:
system controller replace resume
All the non-root aggregates and NAS data LIFs are migrated from node1 to node2.
The operation pauses to allow you to verify whether all node1 non-root aggregates and non-SAN data LIFs have been migrated to node2.
Check the status of the aggregate relocation and NAS data LIF move operations by using the following command:
system controller replace show-details
With the operation still paused, verify that all the non-root aggregates are online for their state on node2 by using the following command:
storage aggregate show -node <node2> -state online -root false
The following example shows that the non-root aggregates on node2 are online:
cluster::> storage aggregate show -node node2 state online -root false Aggregate Size Available Used% State #Vols Nodes RAID Status aggr_1 744.9GB 744.8GB 0% online 5 node2 raid_dp,normal aggr_2 825.0GB 825.0GB 0% online 1 node2 raid_dp,normal 2 entries were displayed.
If the aggregates have gone offline or become foreign on node2, bring them online by using the following command on node2, once for each aggregate:
storage aggregate online -aggregate <aggr_name>
Verify that all the volumes are online on node2 by using the following command on node2 and examining its output:
volume show -node <node2> -state offline
If any volumes are offline on node2, bring them online by using the following command on node2, once for each volume:
volume online -vserver <vserver-name> -volume <volume-name>
The
<vserver-name>
to use with this command is found in the output of the previous volume show command. -
If any LIFs are down, set the administrative status of the LIFs to
up
by using the following command, once for each LIF:network interface modify -vserver <vserver_name> - lif <LIF_name> -home-node <nodename> - status-admin up
