Required tools and documentation
Contributors netapp-barbe
You must have specific tools to install the new hardware, and you need to reference other documents during the upgrade process. You also need to record information essential to completing the controller upgrade; a worksheet is provided to record information.
You need the following tools to perform the upgrade:
  • Grounding strap
  • #2 Phillips screwdriver
Document Contents
ONTAP 9 Software Setup Guide
Describes how to set up and configure NetApp systems
ONTAP 9 System Administration Reference
Describes how to administer ONTAP systems, shows you how to use the CLI interface, how to access the cluster, how to manage nodes, and much more
ONTAP 9 Upgrade and Revert/Downgrade Guide
Contains instructions for downloading and upgrading ONTAP
ONTAP 9 Disks and Aggregates Power Guide
Describes how to manage ONTAP physical storage, shows you how to create, expand, and manage aggregates, how to work with Flash Pool aggregates, how to manage disks, and how to manage RAID policies
ONTAP 9 Logical Storage Management Guide
Describes how to efficiently manage your logical storage resources, using volumes, FlexClone volumes, files and LUNs, FlexCache volumes, deduplication, compression, qtrees, and quotas
Installation and Setup Instructions for the model of the new nodes
Contains instructions for installing and cabling the new system
FlexArray Virtualization Installation Requirements and Reference Guide
Contains cabling instructions and other information for FlexArray Virtualization systems
Hardware Universe
Contains information about system LEDs and system messages to aid troubleshooting
The appropriate disk shelf guide
Contains instructions for installing and monitoring disk shelves and replacing disk shelf devices
ONTAP 9 SAN Administration Guide
Describes how to configure and manage iSCSI and FC protocols for SAN environments
ONTAP 9 SAN Configuration Guide
Contains information about FC and iSCSI topologies and wiring schemes
The NetApp Support Site also contains documentation about network interface cards (NICs) and other hardware that you might use with your system. It also contains the Hardware Universe, which provides information about the hardware that the new system supports. See the ONTAP 9 Documentation Center to access ONTAP 9 product documentation.
