Retire node2
Contributors netapp-pcarriga Download PDF of this page
To retire node2, you need to shut node2 down properly and remove it from the rack or chassis.
Steps
  1. Resume the operation:
    system controller replace resume
    The node halts automatically.
After you finish
You can decommission node2 after the upgrade is completed. See Decommission the old system
