Verify the node3 installation
Contributors netapp-barbe
You must verify that the physical ports from node1 map correctly to the physical ports on node3. This will allow node3 to communicate with other nodes in the cluster and with the network after the upgrade.
About this task
Capture information about the ports on the new nodes from the Hardware Universe. You will use the information later in this section.
Physical port layout might vary, depending on the model of the nodes. When the new node boots up, ONTAP will try to determine which ports should host cluster LIFs in order to automatically come into quorum.
If the physical ports on node1 do not map directly to the physical ports on node3, the subsequent section Restore network configuration on node3 must be used to repair the network connectivity.
After you install and boot node3, you must verify that it is installed correctly. You must wait for node3 to join quorum and then resume the relocation operation.
At this point in the procedure, the operation will have paused as node3 joins quorum.
Steps
  1. Verify that node3 has joined quorum by using the following command:
    cluster show -node node3 -fields health
    The output of the health field should be true.
  2. Verify that node3 is part of the same cluster as node2 and that it is healthy by using the following command:
    cluster show
  3. Switch to advanced privilege mode by using the following command:
    set advanced
  4. Check the status of the controller replacement operation and verify that it is in a paused state and in the same state that it was in before node1 was halted to perform the physical tasks of installing new controllers and moving cables by using the following commands:
    system controller replace show
    system controller replace show-details
  5. If you are working on a MetroCluster system, verify that the replaced controller is configured correctly for the MetroCluster configuration; the MetroCluster configuration should be in a healthy state. See Verify the health of the MetroCluster configuration.
    Reconfigure the intercluster LIFs on MetroCluster node node3, and check cluster peering to restore communication between the MetroCluster nodes before proceeding to Step 6.
    Check the MetroCluster node status by using the following command:
    metrocluster node show
  6. Resume the controller replacement operation by using the following command.
    system controller replace resume
  7. Controller replacement will pause for intervention with the following message:
    Cluster::*> system controller replace show
    Node             Status                       Error-Action
    Node1(now node3) Paused-for-intervention      Follow the instructions given in
                                                  Step Details
    Node2                      None
    Step Details:
    To complete the Network Reachability task, the ONTAP network configuration must be manually adjusted to match the new physical network configuration of the hardware. This includes:
    1. Re-create the interface group, if needed, before restoring VLANs. For detailed commands and instructions, refer to the "Re-creating VLANs, ifgrps, and broadcast domains" section of the upgrade controller hardware guide for the ONTAP version running on the new controllers.
    2. Run the command "cluster controller-replacement network displaced-vlans show" to check if any VLAN is displaced.
    3. If any VLAN is displaced, run the command "cluster controller-replacement network displaced-vlans restore" to restore the VLAN on the desired port.
    2 entries were displayed.
    In this guide, the section Re-creating VLANs, ifgrps, and broadcast domains has been renamed Restore network configuration on node3.
  8. With the controller replacement in a paused state, proceed to the next section of this document to restore network configuration on the node.
After you confirm that node3 is in quorum and can communicate with node2, verify that node1’s VLANs, interface groups, and broadcast domains are seen on node3. Also, verify that all node3 network ports are configured in their correct broadcast domains.
About this task
For more information on creating and re-creating VLANs, interface groups, and broadcast domains, see the ONTAP 9 Network Management Guide.
Steps
  1. List all the physical ports that are on upgraded node1 (referred to as node3) by using the following command:
    network port show -node node3
    All physical network ports, VLAN ports and interface group ports on the node are displayed. From this output, you can see any physical ports that have been moved into the Cluster broadcast domain by ONTAP. You can use this output to aid in deciding which ports should be used as interface group member ports, VLAN base ports or standalone physical ports for hosting LIFs.
  2. List the broadcast domains on the cluster by using the following command:
    broadcast-domain show
  3. List network port reachability of all ports on node3 by using the following command:
    network port reachability show
    You should see output like the following example:
    clusterA::*> reachability show -node node1_node3
    (network port reachability show)
    Node         Port       Expected Reachability   Reachability Status
    node1_node3
                 a0a        Default:Default         no-reachability
                 a0a-822    Default:822             no-reachability
                 a0a-823    Default:823             no-reachability
                 e0M        Default:Mgmt            ok
                 e0a        Cluster:Cluster         misconfigured-reachability
                 e0b        Cluster:Cluster         no-reachability
                 e0c        Cluster:Cluster         no-reachability
                 e0d        Cluster:Cluster         no-reachability
                 e0e        Cluster:Cluster         ok
                 e0e-822    -                       no-reachability
                 e0e-823    -                       no-reachability
                 e0f        Default:Default         no-reachability
                 e0f-822    Default:822             no-reachability
                 e0f-823    Default:823             no-reachability
                 e0g        Default:Default         misconfigured-reachability
                 e0h        Default:Default         ok
                 e0h-822    Default:822             ok
                 e0h-823    Default:823             ok
    18 entries were displayed.
    In the above example, node1_node3 is just booted after controller replacement. Some ports do not have reachability to their expected broadcast domains and must be repaired.
  4. Repair the reachability for each of the ports on node3 with a reachability status other than ok. Run the following command, first on any physical ports, then on any VLAN ports, one at a time:
    network port reachability repair -node <node_name> -port <port_name>
    You should see output like the following sample:
    Cluster ::> reachability repair -node node1_node3 -port e0h
    Warning: Repairing port "node1_node3: e0h" may cause it to move into a different broadcast domain, which can cause LIFs to be re-homed away from the port. Are you sure you want to continue? {y|n}:
    A warning message, as shown above, is expected for ports with a reachability status that might be different from the reachability status of the broadcast domain where it is currently located. Review the connectivity of the port and answer y or n as appropriate.
    Verify that all physical ports have their expected reachability by using the following command:
    As the reachability repair is performed, ONTAP attempts to place the ports in the correct broadcast domains. However, if a port’s reachability cannot be determined and does not belong to any of the existing broadcast domains, ONTAP will create new broadcast domains for these ports.
  5. If interface group configuration does not match the new controller physical port layout, modify it by using the following steps.
    1. You must first remove physical ports that should be interface group member ports from their broadcast domain membership. You can do this by using the following command:
      network port broadcast-domain remove-ports -broadcast-domain <broadcast-domain_name> -ports <node_name:port_name>
    2. Add a member port to an interface group by using the following command:
      network port ifgrp add-port -node <node_name> - ifgrp <ifgrp> -port <port_name>
    3. The interface group is automatically added to the broadcast domain about a minute after the first member port is added.
    4. Verify that the interface group was added to the appropriate broadcast domain by using the following command:
      network port reachability show -node <node_name> -port <ifgrp>
      If the interface group’s reachability status is not ok, assign it to the appropriate broadcast domain by using the following command:
      network port broadcast-domain add-ports -broadcast-domain <broadcast_domain_name> -ports <node:port>
  6. Assign appropriate physical ports to the Cluster broadcast domain by using the following steps:
    1. Determine which ports have reachability to the Cluster broadcast domain by using the following command:
      network port reachability show -reachable-broadcast-domains Cluster:Cluster
    2. Repair any port with reachability to the Cluster broadcast domain, if its reachability status is not ok by using the following command:
  7. Move the remaining physical ports into their correct broadcast domains by using one of the following commands:
    Verify that there are no unreachable or unexpected ports present. Check the reachability status for all physical ports by using the following command and examining the output to ensure the status is ok:
    network port reachability show -detail
  8. Restore any VLANs that might have become displaced by using the following steps:
    1. List displaced VLANs by using the following command:
      displaced- vlans show
      Output like the following should display:
      Cluster::*> displaced-vlans show
      (cluster controller-replacement network displaced-vlans show)
                Original
      Node      Base Port   VLANs
      Node1       a0a       822, 823
                  e0e       822, 823
    2. Restore VLANs that were displaced from their previous base ports by using the following command:
      displaced- vlans restore
      The following is an example of restoring VLANs that have been displaced from interface group a0a back onto the same interface group:
      Cluster::*> displaced-vlans restore -node node1_node3 -port a0a -destination-port a0a
      The following is an example of restoring displaced VLANs on port e0e to e0h:
      Cluster::*> displaced-vlans restore -node node1_node3 -port e0e -destination-port e0h
      When a VLAN restore is successful, the displaced VLANs are created on the specified destination port. The VLAN restore fails if the destination port is a member of an interface group, or if the destination port is down.
      Wait about one minute for newly restored VLANs to be placed into their appropriate broadcast domains.
    3. Create new VLAN ports as needed for VLAN ports that are not in the displaced- vlans show output but should be configured on other physical ports.
  9. Delete any empty broadcast domains after all port repairs have been completed by using the following command:
    broadcast-domain delete -broadcast-domain <broadcast_domain_name>
  10. Verify port reachability by using the following command:
    When all ports are correctly configured and added to the correct broadcast domains, the network port reachability show command should report the reachability status as ok for all connected ports, and the status as no-reachability for ports with no physical connectivity. If any port reports a status other than these two, perform the reachability repair and add or remove ports from their broadcast domains as instructed in Step 4.
  11. Verify that all ports have been placed into broadcast domains by using the following command:
    network port show
  12. Verify that all ports in the broadcast domains have the correct maximum transmission unit (MTU) configured by using the following command:
    network port broadcast-domain show
  13. Restore LIF home ports, specifying the Vserver(s) and LIF(s) home ports, if any, that need to be restored by using the following steps:
    1. List any LIFs that are displaced by using the following command:
      displaced-interface show
    2. Restore LIF home nodes and home ports by using the following command:
      displaced-interface restore-home-node -node <node_name> -vserver <vserver_name> - lif-name <LIF_name>
  14. Verify that all LIFs have a home port and are administratively up by using the following command:
    network interface show -fields home- port,status-admin
